what is your settings for UCSFOLLOW?and or is your viewport LOCKED?
end thee image is a(n) *.SID file too right?
Quote from: mjfarrell on April 14, 2015, 11:34:46 AMend thee image is a(n) *.SID file too right?negative, .ecw
Quote from: Mark on April 14, 2015, 11:36:57 AMQuote from: mjfarrell on April 14, 2015, 11:34:46 AMend thee image is a(n) *.SID file too right?negative, .ecwsame....animal different flavour
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. It is a file format (filename extension .sid) developed and patented by LizardTech for encoding of georeferenced raster graphics, such as orthophotos.
ECW (Enhanced Compression Wavelet) files are compressed images that typically store aerial and satellite map projections. It's a proprietary format developed by Earth Resource Mapping, which is now owned by ERDAS, which in turn is owned by Leica Geosystems.
give JPG a try
Quote from: mjfarrell on April 14, 2015, 11:44:22 AMgive JPG a tryThat worked! Unfortunately I still have to deal with the problem.
Quote from: Mark on April 15, 2015, 01:46:04 PMQuote from: mjfarrell on April 14, 2015, 11:44:22 AMgive JPG a tryThat worked! Unfortunately I still have to deal with the problem.Be sure to thank autodesk for spending your subscription money wisely....this issue is known for over 4 years
