Author Topic: Image moving in viewport  (Read 9424 times)
« on: April 14, 2015, 10:11:48 AM »
I have a drawing with an aerial image inserted into it. When in paperspace while zooming in and out the image will change location within the viewport. Anyone ever see this before?
let me take a few screen shots!
BRB. :)
Re: Image moving in viewport
« Reply #1 on: April 14, 2015, 10:15:53 AM »
Hopefully these well help.
« Reply #2 on: April 14, 2015, 10:47:46 AM »
what is your settings for UCSFOLLOW?
and or is your viewport LOCKED?
« Reply #3 on: April 14, 2015, 11:00:49 AM »
0
and
LOCKED
« Reply #4 on: April 14, 2015, 11:05:15 AM »
It only happens when you rotate the viewport a considerable amount.
« Reply #5 on: April 14, 2015, 11:34:46 AM »
end thee image is a(n)  *.SID   file too right?
You may need the lizardteck veiwer to export it as JPG with world file for your purposes
« Reply #6 on: April 14, 2015, 11:36:57 AM »
negative, .ecw
« Reply #7 on: April 14, 2015, 11:38:08 AM »
negative, .ecw
same....animal different flavour
« Reply #8 on: April 14, 2015, 11:40:41 AM »
If the viewport is rotated 90° +/- its fine. Only when you rotated the viewport some 45° does it start to happen.
« Reply #9 on: April 14, 2015, 11:43:08 AM »
negative, .ecw
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. It is a file format (filename extension .sid) developed and patented by LizardTech for encoding of georeferenced raster graphics, such as orthophotos.
ECW (Enhanced Compression Wavelet) files are compressed images that typically store aerial and satellite map projections. It's a proprietary format developed by Earth Resource Mapping, which is now owned by ERDAS, which in turn is owned by Leica Geosystems.
« Reply #10 on: April 14, 2015, 11:44:22 AM »
give JPG a try
« Reply #11 on: April 15, 2015, 01:46:04 PM »
give JPG a try
That worked! Unfortunately I still have to deal with the problem.
« Reply #12 on: April 15, 2015, 02:04:21 PM »
give JPG a try
Be sure to thank autodesk for spending your subscription money wisely....this issue is known for over 4 years   :evillaugh:    :evillaugh:   :evillaugh:
« Reply #13 on: April 15, 2015, 02:20:03 PM »
give JPG a try
Really? I didn't see it any where.
by the way, how do you report a problem to Autodesk? I couldn't find it any where!
« Reply #14 on: April 15, 2015, 02:26:23 PM »
HERE .. last time I reported something they responded within a couple of days.
