I have a bunch of data I'm working with and one of the fields is in this format:
ABCxxXxxABCjklMZ
Or basically, the first three characters will always be string, then next one, two or possibly three characters will be integers from 0 to 9, then an upper case X followed by one, two or three integers 0 to 9. At this point of the string is where I want to discard everything to the left side of the last integer and grab anything and everything that's to the right of it. I'm pretty sure I can do this with some code, but this looks like it might be a good time for a regular expression. Not being too familiar with them I was hoping to get some advice here.
There may be times when a user puts an upper case X in one of the first three characters so if I do key in on that upper case X between the sets of integers, I'd have to take that into account. But most of the time, that upper case X will occur only between the sets of integers which may contain 1 to 3 digits each. And one set will not always be the same length as the other.
