Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Redefining a block in multiple files via OBJECTDBX Wrapper
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Redefining a block in multiple files via OBJECTDBX Wrapper (Read 2596 times)
MSTG007
Gator
I can't remeber what I already asked! I need help!
on:
April 11, 2015, 09:07:16 AM »
Lee ad awhile ago showed me an awesome way to do some layer management stuff via this.
http://www.theswamp.org/index.php?topic=47376.msg524151#msg524151
I was wondering using his same setup how to change it to redefine 1 block name in mulitple dwgs.
Thanks!
Logged
Civil3D 2020
ttray33y
Mosquito
Re: Redefining a block in multiple files via OBJECTDBX Wrapper
Reply #1 on:
June 14, 2015, 11:26:33 PM »
in my own understanding. ObjectDBX wrapper cannot do that.
Code:
[Select]
http://lee-mac.com/odbxbase.html
Logged
Seagull
London, England
WWW
Reply #2 on:
June 15, 2015, 04:10:10 AM »
You could try the following (untested!):
Code - Auto/Visual Lisp:
[Select]
defun
c:batchredef
blk dwg
while
not
or
setq
blk
getstring
t
\n
Specify block name to redefine: "
setq
dwg
findfile
strcat
blk
".dwg"
princ
strcat
\n
File
blk
".dwg
not found."
if
dwg
LM:odbx
function
lambda
doc
if
not
vl-catch-all-error-p
vl
catch
all
apply
vla-item
list
vla-get-blocks
doc
blk
vla-delete
vla-insertblock
vla-get-modelspace
doc
vlax-3D-point
0
0
dwg
1.0
1.0
1.0
0.0
nil
t
princ
EDIT: On testing the above, this method does not appear to be successful.
Last Edit: June 15, 2015, 04:59:16 AM by Lee Mac
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
