Author Topic: Rotating a profile  (Read 4949 times)
ekoneo
Rotating a profile
« on: April 09, 2015, 03:12:08 AM »
Does anybody know that rotating a profile wiew. I need a vertical wiew style. I can do this by exploding horizontal wiew style and rotating it vertical position. Or I can do it wiewport. But wonder that existance of direct drawing style or options.
Is there a way to draw or rotate the profile for this requarement?
Re: Rotating a profile
« Reply #1 on: April 09, 2015, 08:57:33 AM »
what is it that is going into your 'vertical' profile?
does not the things (profiles) that you want to show in that profile define the vertical elevation changes you require?
ekoneo
« Reply #2 on: April 10, 2015, 05:09:38 AM »
Thanks mjfarrell.
I atached what I need to do.
« Reply #3 on: April 10, 2015, 09:07:15 AM »
why?
« Reply #4 on: April 10, 2015, 09:11:00 AM »
the only way I can imagine this working is using DVIEW/Twist on a profile viewport
I don't see this working in modelspace
And; again I must ask 'why?' do you need the profile to be rotated 90 degrees?
How does this help you?
IF you use sheet tools...you can align the plan view of any street with the profile...
ekoneo
« Reply #5 on: April 16, 2015, 08:47:27 AM »
thanks mjfarrel. I try to plot in one page more than one profile of different aligments. some of them is horizontal some of them ll be located verically in a page. I understand that there is no way of that work as my guess. I was using NetCAD program that allows users to rotate the profile. I gave up using NetCAD after Civil3D2010 version. NetCAD in not dynamic. It creates only geometrik items such as line, point, circle, spline, arc, polyline, etc.. So it is possible to rotate a profile that is droawn nondynamic geometric parts.
This requarement is not so much assential. Thanks mj farrel.
