Author Topic: Revision Clouds  (Read 6913 times)
shaunfella
Revision Clouds
« on: April 07, 2015, 12:00:43 PM »
Hi guys,
New to the forum.  Have been a designer in a few different companies and each time the revision procedure has differed.
Can I ask the forums opinion on this;
If you remove a complete detail/ note/ item etc from the drg - do you cloud that area even though there is nothing there? Some companies may cloud the area and add 'DETAIL/ NOTE.. REMOVED'
Be interested to read what the rest of you do.
Shaunfella
Re: Revision Clouds
« Reply #1 on: April 07, 2015, 12:08:04 PM »
nothing there = no cloud
something to see = cloud + revision number
Rob...
Re: Revision Clouds
« Reply #2 on: April 07, 2015, 12:19:14 PM »
I've seen it all three ways. The simple answer is to follow your company's standard.
CAD Tech
shaunfella
Re: Revision Clouds
« Reply #3 on: April 07, 2015, 12:31:18 PM »
I was brought in to shake things up a bit in the CAD department as there has been a bit of a 'well thats the way we've always done so that's how we do it' that has caused a lot of accumulative issues
Rob...
Re: Revision Clouds
« Reply #4 on: April 07, 2015, 12:34:56 PM »
Whatever you decide, IMHO, there has to be some indication that there was something deleted, either by cloud or by note or both.
CAD Tech
shaunfella
Re: Revision Clouds
« Reply #5 on: April 07, 2015, 12:37:58 PM »
This is also my feeling..why reissue a dwg with no indication that anything has changed!
Re: Revision Clouds
« Reply #6 on: April 07, 2015, 12:41:26 PM »
if a detail is removed....that can or should be added here...on our sheets
not an empty cloud...
empty clouds can cause confusion
Rob...
Re: Revision Clouds
« Reply #7 on: April 07, 2015, 12:45:36 PM »
An empty cloud, if it is on a plan or a detail sheet, can only mean that something has been removed. No confusion at all.
CAD Tech
shaunfella
Re: Revision Clouds
« Reply #8 on: April 07, 2015, 12:47:41 PM »
Again, my feeling is that it needs to be flagged up that something has been amended. However some clients insist on only that particular revision's title .i.e.  Approved for Design, with no additional text. Therefor we cannot annotate as such in the revision block........
Re: Revision Clouds
« Reply #9 on: April 07, 2015, 12:49:32 PM »
OR that something did NOT PLOT....so there is potential for confusion
now if this was years ago...one might even see erasure marks on the blueprints...then it would be clear something had been erased
shaunfella
Re: Revision Clouds
« Reply #10 on: April 07, 2015, 12:49:46 PM »
Do any you guys use Comment Resolution Sheets, or similar, at all?
Re: Revision Clouds
« Reply #11 on: April 07, 2015, 12:52:19 PM »
no
However ...I have seen revision cloud AND  a giant 'watermark' indicating
DETAIL NOT USED and a big X across such a detail
shaunfella
Re: Revision Clouds
« Reply #12 on: April 07, 2015, 12:56:45 PM »
no
the plot thickens!!
Rob...
Re: Revision Clouds
« Reply #13 on: April 07, 2015, 12:58:11 PM »
for people who don't know how to read plans and addenda or bulletins, that's just over analizing. There should be additional documentation for revisions that spells out what the changes are. Deletions would be noted on those.
Personally, I would note that detail has been deleted but I have submitted many empty clouds and there has never been any concern about changing that procedure in the 14 years I've been here. Certainly, if there was any confusion in the field we would have changed our procedure.
CAD Tech
cadtag
Re: Revision Clouds
« Reply #14 on: April 07, 2015, 01:00:18 PM »
I've typically used Michael's approach when a revision requires removing a detail as no longer to be used.  Large "X" across the detail, and revcloud it.
An empty revcloud would confuse the contractors I've dealt with, and I really don't expect the guys in the filed to keep _all_ earlier copies of the prints to cross reference an empty cloud with what was there the previous rev.
