Author Topic: Trying to create a surface from an exploded tin  (Read 2460 times)
Gael
« on: April 06, 2015, 04:16:28 PM »
Hello there,
So I just inherited a job...
For what ever reason, the survey surface isn't the full surface.  I imported the .xml and it is a cropped surface.  However I have a drawing with points.  I have another drawing with the lines from a tin and polylines that represent contours from a tin, but they are just that.  I tried making the surface out of the point file, but I don't have the break lines and they did a lot of post editing for the curves and gutter lines.  So I tried to make a surface out of the lines from the tin (which it does have elevations attached).  So I created a new surface, in prospector when to definition and selected from autocad objects.  It says it has information min and max and number of triangles but I can't get it to display a surface.
Did I miss a step?
Suggestions?
Help is appreciated...
Re: Trying to create a surface from an exploded tin
« Reply #1 on: April 06, 2015, 05:48:56 PM »
what style did you apply?
you could try adding ALL the data you have...Points, Contours and the Triangles....or post your data back here and I'll process it for you...
