Author Topic: Why this is not working  (Read 2472 times)
Zykl0
« on: April 02, 2015, 01:35:03 PM »
I'm working a script that find layer in the drawing by keyword and send everything on this layer to another one. This is not working at all and i don't know why. please help!
(defun C:ACUTEST (/ lay )
  (setq !lay (ssget "x" '((8 . "*Ala*"))))
  (command "_.CHPROP" !lay "" "LA" "Alarm" "")
  (setq !lay (ssget "x" '((8 . "*Ax*"))))
  (command "_.CHPROP" !lay "" "LA" "Axis" "")
  (setq !lay (ssget "x" '((8 . "*Back*"))))
  (command "_.CHPROP" !lay "" "LA" "Background" "")
  (setq !lay (ssget "x" '((8 . "*Be*"))))
  (command "_.CHPROP" !lay "" "LA" "Beam" "")
  (setq !lay (ssget "x" '((8 . "*Buil*"))))
  (command "_.CHPROP" !lay "" "LA" "Building" "")
Matt__W
  • I like my water diluted.
Re: Why this is not working
« Reply #1 on: April 02, 2015, 01:46:53 PM »
Do all of the layers exist?
Autodesk Expert Elite
tombu
  • ByLayer=>Not0
« Reply #2 on: April 02, 2015, 01:49:06 PM »
You need to attach the drawing for us to test.
Tom Beauford P.S.M.
« Reply #3 on: April 02, 2015, 02:06:49 PM »
Quick & dirty for your consideration, coded blind:
(defun C:AcuTest ( / foo )
    (defun foo ( filter layer / ss )
        (if (null (setq ss (ssget "x" (list (cons 8 filter)))))
            (princ (strcat "\nNo entites found for filter <" filter ">."))
                (if (null (tblsearch "layer" layer ))
                    (vl-cmdf ".layer" "_new" layer "")
                (vl-cmdf ".chprop" ss "" "_layer" layer "")
                (princ
                    (strcat
                        "\n"
                        (itoa (sslength ss))
                        " object(s) moved to layer <" layer ">."
    (foreach pair
            ("*Ala*"  "Alarm")
            ("*Ax*"   "Axis")
            ("*Back*" "Background")
            ("*Be*"   "Beam")
            ("*Buil*" "Building")
        (apply 'foo pair)
« Last Edit: April 02, 2015, 02:12:28 PM by MP »
« Reply #4 on: April 02, 2015, 02:17:33 PM »
And another :)
  1. (defun c:acutest (/ ss)
  2.   (foreach lay '(("*Ala*" "Alarm")
  3.                  ("*Ax*" "Axis")
  4.                  ("*Back*" "Background")
  5.                  ("*Be*" "Beam")
  6.                  ("*Buil*" "Building")
  7.                 )
  8.     (if (null (tblobjname "layer" (cadr lay)))
  9.       (vl-cmdf ".layer" "_new" (cadr lay) "")
  10.     )
  11.     (if (setq ss (ssget "_x" (list (cons 8 (car lay)))))
  12.       (command "_.CHPROP" ss "" "Layer" (cadr lay) "")
  13.     )
  14.   )
  15.   (princ)
  16. )
Zykl0
« Reply #5 on: April 04, 2015, 11:15:58 PM »
Wow this is amazing guys!
keep up to good work.
