Author Topic: About viewport  (Read 1860 times)
Fabricio28
About viewport
« on: March 30, 2015, 01:33:42 PM »
Hi guys,
I'm working at the paperspace. I've already created a viewport, and I wanna create other viewport.
But When set a new viewport I'm get stuck in the coordinate 0,0,0.
Help me, please!
ChrisCarlson
Re: About viewport
« Reply #1 on: March 30, 2015, 01:57:59 PM »
Huh? Upload a picture?
Re: About viewport
« Reply #2 on: March 30, 2015, 01:59:02 PM »
Is it locked ?
Fabricio28
Re: About viewport
« Reply #3 on: March 30, 2015, 02:25:32 PM »
Thank you for the quick replay...
I'm not sure if the viewport is locked. How Can I unlocked?
Re: About viewport
« Reply #4 on: March 30, 2015, 03:02:32 PM »
Highlight it and look at the properties palette.
Re: About viewport
« Reply #5 on: March 30, 2015, 03:14:50 PM »
are LIMITS ON and Set?
is your OSNAP /GRID on and enabled thus causing you to snap to 0,0?
try draw rectangle first...then VPCLIP it into a viewport...
Fabricio28
Re: About viewport
« Reply #6 on: March 30, 2015, 03:20:14 PM »
Hi Guys,
Take a look for me please...
Re: About viewport
« Reply #7 on: March 30, 2015, 04:42:48 PM »
turn off or change settings for SNAP mode
at present your paper size is smaller than SNAP increment
thus your viewport appears to remain @ 0,0
it would work if you used
Command: MV MVIEW
Specify corner of viewport or [ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/LAyer/2/3/4] <Fit>:  Second thought probably NOT because SNAP increment is so LARGE
just turn off SNAP <F9>
Fabricio28
Re: About viewport
« Reply #8 on: March 30, 2015, 05:15:07 PM »
Command: MV MVIEW
 :-D
Thank you very much!!
I didn't know what to do, you helped me a lot.
Thank you
« Last Edit: March 31, 2015, 04:07:56 PM by FABRICIO28 »
