Author Topic: HPGL/2 drivers under Win7 x64  (Read 3138 times)
Peter2
« on: March 27, 2015, 06:45:05 AM »
Which HPGL/2 drivers are you using, which good and bad experiences can you report? Who uses the old ones (750? 1050, 1055,..) or the current ones (T770, T1100, ...).
Because I'm checking for "Save HPGL/2 to file" and "plotView" I ask for drivers, not for the plotters  ;-)
Have a fine weekend.
Peter
BricsCAD V23
Re: HPGL/2 drivers under Win7 x64
« Reply #1 on: June 19, 2015, 08:21:44 AM »
Just noticing this thread now...
You want to use an HPGL driver on purpose? I avoid plotting with them if I can.
« Reply #2 on: June 19, 2015, 09:55:39 AM »
You might find that the above does not translate well to German.
Peter2
« Reply #3 on: June 19, 2015, 10:20:20 AM »
..You want to use an HPGL driver on purpose? ...
I think that post-processing is sometimes easier (scaling, cropping white spaces, batch features, ...) and creating output from drawings with embedded raster-image is quicker. Transparency has to be checked ...
To what or to whom are referring to?
Peter
BricsCAD V23
« Reply #4 on: June 19, 2015, 10:25:42 AM »
My mistake, I thought I had seen else where that you were translating between English and German.
No offense was intended.
« Reply #5 on: June 19, 2015, 10:48:04 AM »
Your choice but Postscript is a programming language HPGL is not (images are quicker with HPGL though).
