Author Topic: ssget Multiple Layers stored in LIST  (Read 5596 times)
mailmaverick
« on: March 26, 2015, 03:20:50 PM »
I have a list variable containing multiple layer names (length of list is dynamic) as strings.
For example :
(setq layerlist (list "0" "Layer1" "Layer2" "Layer3" "ABCD" "DEFG" "HIJK"))
I want to make a selection set (ssget) of all entities which are in these above layers.
How to do that in ssget by using layerlist ?
ChrisCarlson
Re: ssget Multiple Layers stored in LIST
« Reply #1 on: March 26, 2015, 03:35:58 PM »
  1.
  2. (setq lst'("0""1""2""3"))
  3.         (defun _layersel ( lst)
  4.                 (apply 'append (subst nil (list nil) (mapcar 'list lst)))
  5.                 (foreach layer lst (ssadd (ssget "_A" (list (cons 8 layer))) ss))
  6.         )
  7.
Perhaps?
« Last Edit: March 26, 2015, 04:07:56 PM by ChrisCarlson »
roy_043
  • BricsCAD 18
« Reply #2 on: March 26, 2015, 04:15:04 PM »
Two options:
Using OR:
  1.   "_X"
  2.   (append
  3.     '((-4 . "<OR"))
  4.     (mapcar '(lambda (lyr) (cons 8 lyr)) layerlist)
  5.     '((-4 . "OR>"))
  6.   )
  7. )
Without OR:
  1. (defun KGA_String_Join (strLst delim)
  2.   (if strLst
  3.     (apply
  4.       'strcat
  5.       (cons
  6.         (car strLst)
  7.         (mapcar '(lambda (a) (strcat delim a)) (cdr strLst))
  8.       )
  9.     )
  10.     ""
  11.   )
  12. )
  13.
  14. (ssget "_X" (list (cons 8 (KGA_String_Join layerlist ","))))
David Bethel
« Reply #3 on: March 26, 2015, 05:23:13 PM »
Maybe :
  1.   (setq layerlist (list "0" "Layer1" "Layer2" "Layer3" "ABCD" "DEFG" "HIJK"))
  2.
  3.   (setq ll '((-4 . "OR>")))
  4.   (foreach l layerlist
  5.         (setq ll (cons (cons 8 l) ll)))
  6.   (setq ll (cons '(-4 . "<OR") ll))
  7.
  8.   (setq ss (ssget "X" ll))
  9.
-David
R12 Dos - A2K
BlackBox
« Reply #4 on: March 26, 2015, 05:25:27 PM »
... Or simply:
  1. (defun _strcat (layers delim)
  2.     delim
  3.     (apply
  4.       'strcat
  5.       (mapcar (function (lambda (x) (strcat x delim))) layers)
  6.     )
  7.   )
  8. )
  9.
  2.
  3. (sssetfirst nil (ssget "_x" (list (cons 8 (_strcat layerlist  ",")))))
  4.
roy_043
  • BricsCAD 18
« Reply #5 on: March 27, 2015, 04:53:56 AM »
... Or simply:
I think your solution is (almost) the same as my 2nd suggestion.
« Reply #6 on: March 27, 2015, 07:02:13 AM »
Using OR:
  1.   "_X"
  2.   (append
  3.     '((-4 . "<OR"))
  5.     '((-4 . "OR>"))
  6.   )
  7. )
This is the route that I would take, as I recall that there may be a limit on the string length for ssget filter list items, and such a limit would obviously be reached earlier than any possible limit on the number of filter list items.
ChrisCarlson
« Reply #7 on: March 27, 2015, 08:54:04 AM »
... Or simply:
  2.     delim
  3.     (apply
  4.       'strcat
  6.     )
  7.   )
  8. )
  9.
  2.
  4.
Wouldn't selecting items on frozen/locked layers cause an error when it comes time to do something with the selection set? Also what happens if you pass a null layer value?
BlackBox
« Reply #8 on: March 27, 2015, 09:10:00 AM »
... Or simply:
Many ways to skin a cat; I posted it for the sole purpose that it is a slight adaptation to what had already been posted. :-)
Using OR:
  1.   "_X"
  2.   (append
  3.     '((-4 . "<OR"))
  5.     '((-4 . "OR>"))
  6.   )
  7. )
I don't particularly like the way the code 'looks'
This:
  1.   "_X"
  2.   '((-4 . "<OR")
  3.     (8 . "0")
  4.     (8 . "Layer1")
  5.     (8 . "Layer2")
  6.     (8 . "Layer3")
  7.     (8 . "ABCD")
  8.     (8 . "DEFG")
  9.     (8 . "HIJK")
  10.     (-4 . "OR>")
  11.   )
  12. )
  13.
... Compared to this:
  1. (ssget "_x" (list (8 . "0,Layer1,Layer2,Layer3,ABCD,DEFG,HIJK")))
  2.
... But... The speed difference is quite impressive - thanks for commenting, as it prompted me to take a second look.
That entirely depends on the logic you build into your code, frankly... Being that this is a would-be sub-function, I'd suggest that your main code handle the qualifying of the members of layerList being passed from the outset, rather than to expect the sub-function to account for user error, YMMV.
As the creator of the list argument being passed, you'd have intentionally passed nil or empty string... Or intentionally written code that allows for such a potentiality in the first place.
Cheers all.
« Last Edit: March 27, 2015, 10:10:12 AM by BlackBox »
« Reply #9 on: March 27, 2015, 10:58:17 AM »
  1. (setq lst'("0""1""2""3"))
  2.         (defun _layersel ( lst)
  3.                 (apply 'append (subst nil (list nil) (mapcar 'list lst)))
  4.                 (foreach layer lst (ssadd (ssget "_A" (list (cons 8 layer))) ss))
  5.         )
I think you are missing a setq expression here:
  1. (apply 'append (subst nil (list nil) (mapcar 'list lst)))
Else the line is redundant since you are not using the return of the apply expression.
mailmaverick
« Reply #10 on: March 27, 2015, 01:47:43 PM »
Thanks to all forum gurus. I just wanted one solution but got multiple.
Thus, I mark this thread as 500% solved.  :-D :-D
