@ 77077: Can you post your functionList.xml?
But that's the default file. You have to edit the file. That is what this topic is about...
Quote from: roy_043 on May 29, 2015, 08:05:07 AMBut that's the default file. You have to edit the file. That is what this topic is about...Hi roy ,Where has the edited file ?
<parser id="lisp_function" displayName="lsp" commentExpr="((;\|.*?\|;)|(;.*?$))"> <function mainExpr="(?<=[\s\(]defun\s)\s*[^\s\(]*" displayMode="$functionName"> </function></parser>
Hi royHere is simple routine...
That works pretty smoothly Roy, thanks!
roy ,I have a new question . set language ----> L--->LISP , ok, function list is ok set language ----> user define language---> function list not ok .
Quote from: 77077 on May 29, 2015, 10:29:30 PMroy ,I have a new question . set language ----> L--->LISP , ok, function list is ok set language ----> user define language---> function list not ok .The info you need is in the file...
for User Defined Languages:<association userDefinedLangName="my user defined language" id="my_udl_passer_id"/><association userDefinedLangName="Autocad" id="my_autocad_passer_id"/>
<association langID="30" id="lisp_function"/>
<association userDefinedLangName="LSP" id="lisp_function"/>
