Author Topic: Notepad+++  (Read 9430 times)
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #15 on: May 29, 2015, 07:59:58 AM »
@ ymg:
About your regular expressions:
1.
What does (?s) do?
2.
To catch single line comments use ;.*?$ instead of ;.*$
77077
Re: Notepad+++
« Reply #16 on: May 29, 2015, 08:01:47 AM »
@ 77077: Can you post your functionList.xml?
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #17 on: May 29, 2015, 08:05:07 AM »
But that's the default file. You have to edit the file. That is what this topic is about...
77077
Re: Notepad+++
« Reply #18 on: May 29, 2015, 08:11:50 AM »
Hi roy ,Where has the edited file ?
77077
Re: Notepad+++
« Reply #19 on: May 29, 2015, 08:24:40 AM »
Hi roy
Here is simple routine
Can add something like this ?
 (defun c:Test (/ st ss)
Select the TAG you want to change its value:[TAG1(1)/TAG2(2)/TAG3(3)/TAG4(4)/TAG5(5)] <TAG1>:
« Last Edit: May 29, 2015, 10:07:35 AM by 77077 »
ymg
Re: Notepad+++
« Reply #20 on: May 29, 2015, 09:05:49 AM »
Roy,
The (?s) was to allow multilines in Notepad++ without having to
check the box.
But I am far from being very fluent with regex, like the song
I still have 10 miles to go on a 9 miles road.
ymg
« Last Edit: May 29, 2015, 09:10:48 AM by ymg »
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #21 on: May 29, 2015, 09:09:10 AM »
This is the parser I have used:
<parser id="lisp_function" displayName="lsp" commentExpr="((;\|.*?\|;)|(;.*?$))">
  <function
    mainExpr="(?&lt;=[\s\(]defun\s)\s*[^\s\(]*"
    displayMode="$functionName">
  </function>
</parser>
I have attached my file.
ChrisCarlson
Re: Notepad+++
« Reply #22 on: May 29, 2015, 09:14:36 AM »
That works pretty smoothly Roy, thanks!
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #23 on: May 29, 2015, 09:23:33 AM »
Hi roy
Here is simple routine...
You should start a new topic for this problem. But IMO your request is strange. Tags are not restricted to the "TAG?" format. Except for quick tests I would never use "TAG1", "TAG2" etc.
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #24 on: May 29, 2015, 09:25:37 AM »
Thanks. Note that if you want the list to also contain the arguments then you should study ymg's suggestions.
77077
Re: Notepad+++
« Reply #25 on: May 29, 2015, 11:37:18 AM »
roy , thanks a lot.  function list is nice .
77077
Re: Notepad+++
« Reply #26 on: May 29, 2015, 10:29:30 PM »
roy ,I have a new question .
set language ----> L--->LISP  , ok, function list is ok
set language ----> user define language---> function list not ok .
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #27 on: May 31, 2015, 11:22:35 AM »
The info you need is in the file...
77077
Re: Notepad+++
« Reply #28 on: May 31, 2015, 12:04:20 PM »
Yes , I open functionlist .xml , but ,I can't understand , can you tell me where I need modify ?
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #29 on: June 01, 2015, 03:59:47 AM »
Info in the file:
for User Defined Languages:
<association userDefinedLangName="my user defined language" id="my_udl_passer_id"/>
<association userDefinedLangName="Autocad" id="my_autocad_passer_id"/>
So after:
<association langID="30" id="lisp_function"/>Insert:
<association userDefinedLangName="LSP" id="lisp_function"/>Change "LSP" to match your name.
