Author Topic: Notepad+++  (Read 9403 times)
ChrisCarlson
Notepad+++
« on: March 26, 2015, 09:42:09 AM »
Does anyone have a function parser (functionList.xml) for notepad+++?
huiz
  • Certified Prof C3D
Re: Notepad+++
« Reply #1 on: March 26, 2015, 09:45:12 AM »
Here is one.
ChrisCarlson
Re: Notepad+++
« Reply #2 on: March 26, 2015, 10:00:39 AM »
Looks to be the "stock" functionList.xml file?
My regex skills are severely lacking but I think it would be something along these lines?
<association ext = ".lsp" id="autolisp_function"/>
<parser id="autolisp_function" displayname="AutoLisp">
<function
mainExpr="mainExpr="/([(defun])\w+$/ig"
displayMode="$functionName">
        <functionName>
<nameExpr expr="/[_]\w+/igm"/>
</functionName>
</function>
</parser>
But that's not it :confused:
« Last Edit: March 26, 2015, 10:22:39 AM by ChrisCarlson »
huiz
Re: Notepad+++
« Reply #3 on: March 26, 2015, 10:56:36 AM »
You didn't want that one?
ChrisCarlson
Re: Notepad+++
« Reply #4 on: March 26, 2015, 12:13:44 PM »
No, that file comes default with the installation. The end user has the ability to add in custom function traps. Which in turn, add the function to the function list for easy finding or referencing.
huiz
Re: Notepad+++
« Reply #5 on: March 26, 2015, 01:14:23 PM »
In your AppData path you can find the personal file which you can edit. Mine is exact the same as the original so I never added or changed something :-)
ymg
Re: Notepad+++
« Reply #6 on: March 27, 2015, 03:06:56 PM »
Chris,
Not too good at regex but this one
seems to work for me.
<parser id="lisp_function" displayName="Lisp">
<function
mainExpr="[ \t]*\([ \t]*defun[ \t][a-zA-Z0-9_+\-*/<>=:.!?@%&|]+"
displayMode="$className->$functionName">
</function>
</parser>
Also added the following line in association
<association langID="30" id="lisp_function"/>
Probably would need to add a regex to catch the comments.
ymg
« Last Edit: March 27, 2015, 03:24:43 PM by ymg »
ymg
Re: Notepad+++
« Reply #7 on: March 27, 2015, 03:40:21 PM »
Chris,
Here, may be a bit better with the argument to the function.
     <function
  mainExpr="[ \t]*\([ \t]*defun[ \t]+[a-zA-Z0-9_+\-*/<>=:.!?@%&|]+[ \t]+\([a-zA-Z0-9_+\-*/<>=:.!?@%&| \t]*\)"
     </function>
</parser>
ChrisCarlson
Re: Notepad+++
« Reply #8 on: March 27, 2015, 03:49:10 PM »
Very nice! Thanks!
ymg
Re: Notepad+++
« Reply #9 on: March 28, 2015, 04:24:18 AM »
Chris,
This regex
(?s);\|.*?\|; will find multiple lines comments,
while this one
;.*$ will find single-line comment.
However, I could not make it work in the parser for Function list.
Maybe you have better luck than me.
ymg
ymg
Re: Notepad+++
« Reply #10 on: March 28, 2015, 03:21:05 PM »
Chris,
Here the parser with a much simpler regex.
<function
     mainExpr="\(defun.*?\)"
</function>
</parser>
Still haven't found the trick to exclude comments though.
And a few regex that could be handy in Autolisp:
Single Line Comments in Autolisp:       ;.*$
Multiple Lines Comments Autolisp:       (?s);\|.*?\|;
Comments Single or Multilines:            (((?s);\|.*?\|;)|(;.*$))
Function Name with Parameters:         \(defun.*?\)
Function Name without (defun  :         (?<=defun).*?\)
Within Double or Single Quotes:          (["'])(\\?.)*?\1
Within Balanced Parentheses:              \((?>[^()]|(?R))*\)
Most of the above was pulled or derived  from http://www.regular-expressions.info
ymg
« Last Edit: March 31, 2015, 10:56:46 AM by ymg »
77077
Re: Notepad+++
« Reply #11 on: May 27, 2015, 08:46:39 PM »
New version no function list plug-in  ,I still use old version
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #12 on: May 28, 2015, 11:51:33 PM »
In the latest version V6.7.8.2 the function list works just fine.
77077
Re: Notepad+++
« Reply #13 on: May 29, 2015, 03:21:18 AM »
I just download v6.7.8.2  , but function list  is  null
roy_043
  • BricsCAD 18
Re: Notepad+++
« Reply #14 on: May 29, 2015, 07:52:26 AM »
@ 77077: Can you post your functionList.xml?
