Author Topic: Notepad+++  (Read 9380 times)
77077
Re: Notepad+++
« Reply #30 on: June 01, 2015, 04:49:52 AM »
Info in the file:
for User Defined Languages:
<association userDefinedLangName="my user defined language" id="my_udl_passer_id"/>
<association userDefinedLangName="Autocad" id="my_autocad_passer_id"/>
So after:
<association langID="30" id="lisp_function"/>Insert:
<association userDefinedLangName="LSP" id="lisp_function"/>Change "LSP" to match your name.
Thank you ,roy, now is successful !
Q1241274614
Re: Notepad+++
« Reply #31 on: July 07, 2015, 06:57:00 AM »
(startapp "notepad.exe" FILENAME)
Jota123457
  • Mosquito
Re: Notepad+++
« Reply #32 on: May 13, 2017, 08:21:31 AM »
You are great!
I'm still using Notepadd++  ( :knuppel2:) with autolisp and finaly the functionlist is working.
1000 Thanks! :yay!:
