Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
Vertically Challenged
Land Lubber / Geographically Positioned
Topic:
Connect to MDB - Civil 3D 2014
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Connect to MDB - Civil 3D 2014 (Read 3460 times)
Matt__W
Seagull
I like my water diluted.
on:
March 19, 2015, 03:59:22 PM »
I'm trying to connect to an MDB file and I'm not quite sure where to begin. I've read posts about ESRI MDB files. I'm not sure if that's what I have or if it's formatted differently. I've tried following this link but when I click ADD my only option is for SQL server. I don't see anything for MDB. HELP!!!
http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Failed-to-create-when-trying-to-Attach-Access-Database-in-Map-3D.html
Logged
Autodesk Expert Elite
Owner/FAA sUAS Pilot @
http://skyviz.io
Seagull
Every Student their own Lesson
WWW
Re: Connect to MDB - Civil 3D 2014
Reply #1 on:
March 19, 2015, 04:06:32 PM »
where is that MDB file located?
Is it on the Server?
Or is it local?
Logged
Matt__W
Seagull
Reply #2 on:
March 19, 2015, 04:10:20 PM »
It's local. Or I could put it on a network drive. Whichever is easiest.
Logged
http://skyviz.io
Seagull
WWW
Reply #3 on:
March 19, 2015, 04:10:51 PM »
see attached
you most likely want to use option one....
unless it on a server....in which case you will want to use dataconnect through Map Taskpane <MAPWSPACE>
and you will need log-in credentials...and other particulars of the data store
Logged
Seagull
WWW
Reply #4 on:
March 19, 2015, 04:13:32 PM »
actually option 1 <oops> I forgot you said MDB
Logged
Seagull
WWW
Reply #5 on:
March 19, 2015, 04:18:43 PM »
this used to be done through MAP until autodesk or microsoft decided otherwise...and it was WAY easier then
Logged
Matt__W
Seagull
Reply #6 on:
March 19, 2015, 04:19:17 PM »
What do you mean "option 1"? User DSN?
When I click ADD this is what I get. I don't have an option for MDB although it shows on the first tab.
Logged
http://skyviz.io
Seagull
WWW
Reply #7 on:
March 19, 2015, 04:20:03 PM »
you will want to configure....its already there...MDB
Logged
Matt__W
Seagull
Reply #8 on:
March 19, 2015, 04:21:31 PM »
Logged
http://skyviz.io
Matt__W
Seagull
Reply #9 on:
March 19, 2015, 04:22:05 PM »
Do you know if the driver(s) are located in the install MSI? Or is this strictly a Windows thang?
Logged
http://skyviz.io
Seagull
WWW
Reply #10 on:
March 19, 2015, 04:23:19 PM »
and....there will be this...to deal with
https://support.microsoft.com/en-us/kb/2721825
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
Topic:
