Author Topic: Connect to MDB - Civil 3D 2014  (Read 3437 times)
Matt__W
  • I like my water diluted.
« on: March 19, 2015, 03:59:22 PM »
I'm trying to connect to an MDB file and I'm not quite sure where to begin. I've read posts about ESRI MDB files. I'm not sure if that's what I have or if it's formatted differently. I've tried following this link but when I click ADD my only option is for SQL server. I don't see anything for MDB. HELP!!!
http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Failed-to-create-when-trying-to-Attach-Access-Database-in-Map-3D.html
Autodesk Expert Elite
Re: Connect to MDB - Civil 3D 2014
« Reply #1 on: March 19, 2015, 04:06:32 PM »
where is that MDB file located?
Is it on the Server?
Or is it local?
Matt__W
« Reply #2 on: March 19, 2015, 04:10:20 PM »
It's local. Or I could put it on a network drive. Whichever is easiest.
« Reply #3 on: March 19, 2015, 04:10:51 PM »
see attached
you most likely want to use option one....
unless it on a server....in which case you will want to use dataconnect through Map Taskpane <MAPWSPACE>
and you will need log-in credentials...and other particulars of the data store
« Reply #4 on: March 19, 2015, 04:13:32 PM »
actually option 1 <oops> I forgot you said MDB
« Reply #5 on: March 19, 2015, 04:18:43 PM »
this used to be done through MAP  until autodesk or microsoft decided otherwise...and it was WAY easier then
Matt__W
« Reply #6 on: March 19, 2015, 04:19:17 PM »
What do you mean "option 1"? User DSN?
When I click ADD this is what I get. I don't have an option for MDB although it shows on the first tab.
« Reply #7 on: March 19, 2015, 04:20:03 PM »
you will want to configure....its already there...MDB
Matt__W
« Reply #8 on: March 19, 2015, 04:21:31 PM »
 :tickedoff:
Matt__W
« Reply #9 on: March 19, 2015, 04:22:05 PM »
Do you know if the driver(s) are located in the install MSI? Or is this strictly a Windows thang?
« Reply #10 on: March 19, 2015, 04:23:19 PM »
and....there will be this...to deal with
https://support.microsoft.com/en-us/kb/2721825
