I'm developing a program for AutoCAD 2010, which needs to interact with the MS-Access database.
The system details are:
ACAD 2010
VB.Net
Windows XP
Vis. Studio 2008
In the solution I've referenced "Interop.ADODB.dll v2.8" assembly and using adodb connection to access the database. The program works fine in the XP systems.
But, when I run the program in Windows 7 systems, it throws an error (refer the screenshot) when trying to connect the database.
But, I'm using the same method in the normal windows exe. It is working fine. But in AutoCAD, it gives the error.
Should I need to compile separate dlls on XP and WIN7 systems or is there any other solution ?
Note: I also did reverse approach. Compiled the program in WIN7 system and tested it in the XP system. In this case, it did not show that error.
Please suggest a solution.
Regards,
gsktry
