Author Topic: Delete Mviews via Command line  (Read 1741 times)
MSTG007
« on: March 17, 2015, 04:12:49 PM »
How can you erase / delete a viewport in on current layout tab thru the command line without a user using a mouse to select it?
Civil3D 2020
ChrisCarlson
Re: Delete Mviews via Command line
« Reply #1 on: March 17, 2015, 04:26:02 PM »
view, select named view, delete?
MSTG007
« Reply #2 on: March 17, 2015, 04:29:59 PM »
Is there a way to type (*) since I do not know what the mview name would be?
Civil3D 2020
« Reply #3 on: March 17, 2015, 04:45:21 PM »
qselect
ROBBO
« Reply #4 on: March 18, 2015, 04:39:42 AM »
(ssget "x" '((0 . "VIEWPORT")))(command ".ERASE" "p" "")
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
MSTG007
« Reply #5 on: March 18, 2015, 08:18:32 AM »
Thank you so much!
(defun c:vpdelc nil
  (if (ssget "_x" (list '(0 . "VIEWPORT") (cons 410 (getvar 'ctab))))
    (command "_erase" "p" "" "")
Civil3D 2020
ChrisCarlson
« Reply #6 on: March 18, 2015, 08:42:01 AM »
Seems a little dangerous as this would delete all? What would even be the purpose of delete all?
MSTG007
« Reply #7 on: March 18, 2015, 08:47:46 AM »
I was trying to get it to delete the mview on the current tab only.
Civil3D 2020
cadtag
« Reply #8 on: March 18, 2015, 11:34:52 AM »
well, April 1st is coming.... gotta have some random gag
