What happens when you enter this on the command line of the issue computer?explorer.exe /n,/e,"S:\CAD_Standards\_SE_Custom\Piping\Symbols\Blocks\Iso_Symbols"
You could try this alternative:Code - Auto/Visual Lisp: [Select](defun _opendirectory (path / sa) (if (and (eq 'str (type path)) (findfile (vl-string-right-trim "\\" path)) (setq sa (vlax-create-object "Shell.Application")) ) (progn (vlax-invoke sa 'explore path) (vlax-release-object sa)) ) (princ)) (_opendirectory "S:\\CAD_Standards\\_SE_Custom\\Piping\\Symbols\\Blocks\\Iso_Symbols") ;; Handy function(defun c:cd nil (_opendirectory (getvar 'dwgprefix)))
Couple things, known virus / malware free?A modified routine from Ron would be this;Code - Auto/Visual Lisp: [Select] (defun _opendirectory (path / sa) (if (and (eq 'str (type path)) (findfile (vl-string-right-trim "\\" path)) (setq sa (vlax-create-object "Shell.Application")) ) (progn (vlax-invoke sa 'explore path) (vlax-release-object sa)) ) (princ)) (defun c:cd nil (_opendirectory "S:\\CAD_Standards\\_SE_Custom\\Piping\\Symbols\\Blocks\\Iso_Symbols")) "cd" to run
Quote from: ChrisCarlson on March 17, 2015, 01:18:38 PMCouple things, known virus / malware free?A modified routine from Ron would be this;Code - Auto/Visual Lisp: [Select] (defun _opendirectory (path / sa) (if (and (eq 'str (type path)) (findfile (vl-string-right-trim "\\" path)) (setq sa (vlax-create-object "Shell.Application")) ) (progn (vlax-invoke sa 'explore path) (vlax-release-object sa)) ) (princ)) (defun c:cd nil (_opendirectory "S:\\CAD_Standards\\_SE_Custom\\Piping\\Symbols\\Blocks\\Iso_Symbols")) "cd" to runThis works perfect. Thank you all very much!!
@ronjonp good function.
