Author Topic: Sheet set publishing weirdness  (Read 2891 times)
cadtag
« on: March 12, 2015, 04:57:21 PM »
Here's a fun one....  publishing a complete sheet set from c3d 2014 to an HP plotter on the network.  Acad processes all the sheets, opening each one,   but only the last sheet in the sheet set comes out of the plotter.
The only thing more dangerous to the liberty of a free people than big government is big business
Rob...
Re: Sheet set publishing weirdness
« Reply #1 on: March 12, 2015, 05:02:41 PM »
No offense but that sounds like OIE. Double check all your settings
CAD Tech
ChrisCarlson
« Reply #2 on: March 13, 2015, 08:07:19 AM »
Publish to PDF, if this fails it's an issue with the way the sheet set is setup.
Are all pages setup properly in the page setup manager / plot window of each layout?
« Reply #3 on: March 13, 2015, 08:10:17 AM »
could be the port or printer is set to not spool the print job.......
cadtag
« Reply #4 on: March 13, 2015, 09:48:05 AM »
no offense taken.  PEBCAK is not a rare experience.. :-P.  All the sheets have a functioning layout, and can be plotted by that layout w/o any problem.  Acad seems happy publishing, in that each file is opened and appears to be published -- just hosed at the plotter.  this job has been published successfully a number of times from SSM
I suspect that Michael is on the money -- & that IT has been screwing around with the queues again
Rob...
« Reply #5 on: March 13, 2015, 10:10:00 AM »
This is going to sound off base but check the PDF settings in publisher. If it is set to multi-sheet file, only one file gets sent to printer. If single sheet is selected, then multiple files get queued.
CAD Tech
cadtag
« Reply #6 on: March 15, 2015, 04:51:01 PM »
Interesting ...  will check that next week
