Author Topic: (C3D 2015) Line weights in Alignment Styles  (Read 8310 times)
  • Custom Title
« on: March 05, 2015, 09:14:45 AM »
How do I get the lineweights to display on my 'tick'? I'm using a standard Line in my tick block with no lineweights set. What the heck am i missing here!
thanks
Re: (C3D 2015) Line weights in Alignment Styles
« Reply #1 on: March 05, 2015, 09:20:59 AM »
do you have line weight display enabled?
and or
Display Plot Styles?
AND
is your plot style set to use OBJECT Line weight?
« Reply #2 on: March 05, 2015, 09:25:55 AM »
actually the culprit
aectickline (it's a block)
One would probably be happier drawing a line element in the label style instead...
  • Custom Title
« Reply #3 on: March 05, 2015, 09:28:17 AM »
1 do you have line weight display enabled?
2 Display Plot Styles?
3 is your plot style set to use OBJECT Line weight?
Yes, yes and yes.
the tick is a block i created. I'll look into drawing a line element in the label style.
« Reply #4 on: March 05, 2015, 09:28:39 AM »
« Reply #5 on: March 05, 2015, 09:29:56 AM »
Yes, yes and yes.
then it is the SAME problem only you can't blame autodesk for it   :grinwink:
you would then want to set the lineweight in the block - if you insist on using that block
  • Custom Title
« Reply #6 on: March 05, 2015, 09:43:46 AM »
No workie on the line element. You can't anchor the station correctly.
  • Custom Title
« Reply #7 on: March 05, 2015, 09:44:27 AM »
I suppose so! But I need different lineweights for major and minor stations.
« Reply #8 on: March 05, 2015, 09:45:29 AM »
where do you want to anchor the line?  or station value
and yes I can
« Last Edit: March 05, 2015, 09:51:47 AM by mjfarrell »
  • Custom Title
« Reply #9 on: March 05, 2015, 09:52:32 AM »
OK, i figured it out. Tricky!! But I think I actually like the block better. LOL
« Reply #10 on: March 05, 2015, 09:54:45 AM »
or...
« Reply #11 on: March 05, 2015, 09:56:20 AM »
I use a line element over a block...as there is a much smaller chance ANYONE will ever change that line....
whereas the block could potentially be edited...much easier by some hack accidentally
  • Custom Title
« Reply #12 on: March 05, 2015, 10:01:08 AM »
I can see your point. Once you know how to configure the damn thing it works pretty well.
thanks!
  • Custom Title
« Reply #13 on: March 05, 2015, 10:06:31 AM »
Final product. :)
« Reply #14 on: March 05, 2015, 10:09:40 AM »
oooooo
