Author Topic: MicroStation......Options..(?)  (Read 1545 times)
PHX cadie
« on: March 03, 2015, 12:27:29 PM »
Is there a way to export and save MS settings sim to Acad options?
I temp lost the Function keys. Retreived by purging copies but a big scare for me. Doubt if I can function w/o my side button f keys.
Acad 2013 and XM
ChrisCarlson
Re: MicroStation......Options..(?)
« Reply #1 on: March 03, 2015, 12:59:03 PM »
There is an import / export .exe for AutoCAD to import or export your settings. In your situation it would be simpler to "Reset Settings to Default"
Derp, misread the question
« Last Edit: March 03, 2015, 01:37:53 PM by ChrisCarlson »
« Reply #2 on: March 03, 2015, 01:17:17 PM »
If you are reinstalling the same version of MicroStation or want to backup / restore your user preferences file, you can follow the steps here below:
To backup you User Preference File:
1. Open MicroStation with any file and open the Key-in panel (Utilities->key-in)
2. Type the following string in MicroStation’s key-in panel and press enter:
              $ % explorer  $(_USTN_HOMEPREFS)
             This will open your user preferences folder in windows explorer
3. Copy the required .upf file(s) - there will be one for each MicroStation User - file in your backup folder.
To restore your User Preference File:
3. Close MicroStation but keep the windows explorer window open
4. Copy the backed up .upf file in the above folder, overwriting the existing copy
NOTE: if you are restoring a .upf file for a custom MicroStation user (different from the "untitled" and "examples" that are delivered with the application) after a MicroStation reinstall, you will need to make sure that the corresponding user configuration file (.ucf file) is present in the correct "Users" folder.
« Reply #3 on: March 03, 2015, 01:47:17 PM »
Microstation sounds like a horribly unpolished product.  :wideeyed2:
PHX cadie
« Reply #4 on: March 03, 2015, 04:37:27 PM »
Thxs all !!
Acad 2013 and XM
