Author Topic: LARGEOBJECTSUPPORT variable  (Read 1600 times)
Andrea
« on: February 27, 2015, 01:24:11 PM »
Hi All,
i'm actually experimenting some tests with the LARGEOBJECTSUPPORT variable..
is any of you guys had some info about it ?
thank you.
Keep smile...
Re: LARGEOBJECTSUPPORT variable
« Reply #1 on: February 27, 2015, 02:14:32 PM »
This limit is relevant if you work with very large objects, and you need to save drawings to an earlier format.
0
Use the legacy object-size limits from AutoCAD 2009-based products and prior: 256 MB compressed size for any single object in a drawing
1
Use AutoCAD 2010-based object-size limits: 4 GB compressed size for any single object in a drawing
The above would suggestion caution in it's use.
« Reply #2 on: February 27, 2015, 02:16:50 PM »
further:
Drawings saved to legacy drawing file formats (2007 DWG format or earlier) do not support objects larger than 256MB. The 2010 DWG format removes this limitation.
The LARGEOBJECTSUPPORT system variable controls the object size limits and the warning messages displayed when a drawing is saved.
If either of the following limits are exceeded, the drawing cannot be saved to a 2007 DWG format or earlier drawing file format until the issues are resolved. Resolve the size limits by breaking the drawing or objects up into several drawings or objects.
Drawing files cannot exceed an internal size limit of 4GB, as measured by the total size of all objects in a drawing when uncompressed. Since a drawing file is normally compressed, the final size of a saved drawing file on disk will vary based on the size and number of objects in a drawing.
Each individual object in a drawing cannot exceed an uncompressed size limit of 256MB. For example, a mesh object, when the drawing is saved and compressed, might be 75MB in size while the same object when uncompressed might be 257MB.
Note When working with a 64-bit release, you can work with large objects and drawings more efficiently. However, the drawing files you create might be too large to open with a 32-bit release version of the same product.
AND
To Maintain Large Object Compatibility With Legacy Drawing File Formats
Right-click the drawing area and choose Options.
On the Open and Save tab, under the File Save heading, select the Maintain Drawing Size Compatibility check box.
Andrea
« Reply #3 on: March 04, 2015, 10:18:28 AM »
Thank you...
I'll make few tests..
I did a search on theswamp with this variable...but no result..
Now, we have something.  :)
Cheers !
Keep smile...
