Author Topic: Macro to Rename Xref  (Read 3491 times)
MSTG007
« on: February 26, 2015, 01:56:43 PM »
I am looking for a method that via command prompt or lisp, that I can get an xref to rename to a generic name, and then load a .las file.
I guess the thought is, if I have a ABCD.1234.SH.Siteb.dwg, that I can rename that to .SH.S, then import the .LAS.
(I have made a .LAS that I exported the Layer State Out using the .SH.S) I figured I could rename the project xref to a generic name then import the layer state, activate the layer state, then be done).
I do have a slight variation of naming with this type of file, it could be either:
ABCD.5678.SH.Siteb.dwg
ABCD.1234.SH.SB.dwg
ABCD.4567.SH.Sitereference.dwg
I did not know if maybe a the user could pick the Xref in the drawing, that would then be renamed to the generic name and go from there.
Just a brain storm... Thanks for any ideas.
Civil3D 2020
Re: Macro to Rename Xref
« Reply #1 on: February 26, 2015, 02:11:45 PM »
What does this accomplish ?
MSTG007
« Reply #2 on: February 26, 2015, 02:29:15 PM »
I have created layer states for demo plan, site plan, utility plan.
I have a proposed base file named similar to the above. I then in my proposed base file turn on and change colors to layers that I want to see in the utility plan. Once I get it to look the way I want. I save the file and then Xref that proposed base file into a clean dwg. So if the file name is ABCD.1234.SH.Siteb.dwg. I go to the manager and rename it to .SH.S. I open the layer manager then create a layer state called proposed base for utility plan.
The idea is that I can make this a generic layer state for the proposed base to be loaded into any new or old project (utility plan). So if I were to open an older project's Utility Plan. the proposed base name is this ABCD.5678.SH.SB.dwg. I can then rename that to be .SH.S , Open the Layer State manager and import the proposed base for utility plan in, then activate it. Changes everything to the correct colors and on off layers.
I hopefully explained it as clear as I can. I can manually do all this, so the process does work. Just wanting a way to kinda automate it.
Civil3D 2020
roy_043
  • BricsCAD 18
« Reply #3 on: February 26, 2015, 02:59:42 PM »
Do you mean something along these lines:
(vlax-for blockDefObj (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
  (if (= (vla-get-isxref blockDefObj) :vlax-true)
      ((wcmatch (setq oldName (vla-get-name blockDefObj)) "*ABC")
        (if (tblobjname "block" "ABC")
          (princ "\Error: ABC already exists ")
            (vla-put-name blockDefObj "ABC")
            (layerstate-import "ABC.las")
            (vla-put-name blockDefObj oldName)
      ((wcmatch oldName "*DEF")
      ((wcmatch oldName "*GHI")
EDIT: Replaced foreach with vlax-for as per ronjonp's remark.
« Last Edit: March 02, 2015, 08:04:50 AM by roy_043 »
« Reply #4 on: February 26, 2015, 03:21:26 PM »
Oh .. I get it now after looking at Roy's code ( takes some a bit longer ) :)
Here's a base using the three example layerstates in the post above.
  1. (defun c:foo (/ demo ls_path oldname site util)
  2.   ;; Assumes that these are your file naming conventions for the relevent xref
  3.   ;; Searches for a wildcard match *site* and renames accordingly
  4.   (setq ;; LAS file needs to be named ".SH.S.las"
  5.         site    ".SH.S"
  6.         ;; LAS file needs to be named ".SH.D.las"
  7.         demo    ".SH.D"
  8.         ;; LAS file needs to be named ".SH.U.las"
  9.         util    ".SH.U"
  10.         ;; DUH :)
  11.         ls_path "C:\\MyPath\\To\\Saved\\LayerStates\\"
  12.   )
  13.     (if (= (vla-get-isxref bdf) :vlax-true)
  14.       (cond ;; Check that we have a wildcrad match
  15.             ((wcmatch (strcase (setq oldname (vla-get-name bdf))) (strcat "*" site "*"))
  16.              (if (not (tblobjname "block" (substr site 1 5)))
  17.                (progn ;; Put name to ".SH.S"
  18.                       (vla-put-name bdf (substr site 1 5))
  19.                       ;; Import the already saved layerstate
  20.                       (layerstate-import (strcat ls_path (substr site 1 5) ".las"))
  21.                       ;; Restore the layerstate
  22.                       (layerstate-restore (substr site 1 5) nil 1)
  23.                       ;; Restore xref name
  24.                       (vla-put-name bdf oldname)
  25.                )
  26.              )
  27.             )
  28.             ((wcmatch (strcase (setq oldname (vla-get-name bdf))) (strcat "*" demo "*"))
  29.              (if (not (tblobjname "block" (substr demo 1 5)))
  30.                (progn (vla-put-name bdf (substr demo 1 5))
  31.                       (layerstate-import (strcat ls_path (substr demo 1 5) ".las"))
  32.                       (layerstate-restore (substr demo 1 5) nil 1)
  33.                       (vla-put-name bdf oldname)
  34.                )
  35.              )
  36.             )
  37.             ((wcmatch (strcase (setq oldname (vla-get-name bdf))) (strcat "*" util "*"))
  38.              (if (not (tblobjname "block" (substr util 1 5)))
  39.                (progn (vla-put-name bdf (substr util 1 5))
  40.                       (layerstate-import (strcat ls_path (substr util 1 5) ".las"))
  41.                       (layerstate-restore (substr util 1 5) nil 1)
  42.                       (vla-put-name bdf oldname)
  43.                )
  44.              )
  45.             )
  46.       )
  47.     )
  48.   )
  49.   (princ)
  50. )
« Last Edit: February 26, 2015, 04:39:30 PM by ronjonp »
« Reply #5 on: February 26, 2015, 03:54:49 PM »
Updated code above to use VLAX-FOR vs. FOREACH  :oops:  ( Roy you need to change yours ).
*Added some comment above so OP can troubleshoot.
« Last Edit: February 26, 2015, 04:09:49 PM by ronjonp »
MSTG007
« Reply #6 on: February 26, 2015, 04:34:11 PM »
Awesome. Thanks for the help! Here is what I am doing.
I have a C:\work\layer_states\ (folder created)
I have the .SH.S.las, .SH.D.las, and the .SH.U.las.
I have xref'd a project proposed base. then in the xref manager renamed it to .SH.XREF.S.
I load the lisp and type foo. and I think I broke it.
Civil3D 2020
« Reply #7 on: February 26, 2015, 04:40:46 PM »
Copy the code above again .. had a typo .. hopefully it works as I'm coding blindly ( no test files )
« Reply #8 on: February 26, 2015, 04:45:21 PM »
Now you've lost me. The code should rename the xref before it imports and restores the layer state.
Per your examples, I assumed that your naming convention was this:
*.SH.S* = Site Plans
*.SH.D* = Demo
*.SH.U* = Utility
MSTG007
« Reply #9 on: February 26, 2015, 05:10:11 PM »
No. You are right what you just stated. I just can not seem to get it to work.
Civil3D 2020
MSTG007
« Reply #10 on: February 26, 2015, 05:21:15 PM »
Ok... I have rebooted and still am not having any luck. This is just a thought but I do not need to select the xref first to apply the layer state too or do I?
Civil3D 2020
roy_043
  • BricsCAD 18
« Reply #11 on: March 02, 2015, 08:06:09 AM »
Code updated. Good catch ronjonp.
