Author Topic: Working on my new SDUCT release..  (Read 3498 times)
Andrea
« on: February 24, 2015, 04:40:51 PM »
Hi all,..
Just showing my work to get some comment..
I'm actually remaking my tool SDUCT, to allow more flexibility, compatibility and options.
any comment will be appreciated.
thank you.
Simple Gif,
Keep smile...
Keith Brown
Re: Working on my new SDUCT release..
« Reply #1 on: February 24, 2015, 06:07:57 PM »
Hi Andrea,
That looks really good.
Have you thought about adding fabrication information to the ductwork?  i.e.  cutlengths on duct, flange information, etc?
bilançikur
« Reply #2 on: February 25, 2015, 03:23:56 AM »
Hi Andrea,
This is looking very very good!
I am surprised by the ideas you have (like the "i" toggle for isoliation).
The idea of a dockable form is great, I find it better than modal / modeless forms.
I will certainly check it out!
And from what I know from your other tools, I think we have seen nothing yet.
Thanks.
Andrea
« Reply #3 on: February 25, 2015, 12:34:24 PM »
Hi Andrea,
Hi Keith.
thank you...
I've few idea of concept, such as clash detection made in 2D, duct pieces to make FAB, Tag ID insertion of each piece,
Uniline design, duct reiforcement as per custom standard, CFM calculating, etc...
but for now, I'm only making this Tools for engineering drafters who need to standardize their drawing and be more productive by making double line ductwork with Elbows, turning vanes, tapers, offsets etc....all this without creating and switching layers, making text, linetypes etc..who is a valuable waste of time.
All options can be personalized to allow more flexibility.
I'll include similar function as
DUCTATTACH
and
DUCTCONNECT
and
TAPER
I'll take your note of adding Joint type of ductwork by standard type. this is a good Idea  thank you.
Keep smile...
Andrea
« Reply #4 on: February 25, 2015, 12:35:30 PM »
Hi Andrea,
Thanks.
Thank you Bilançikur  :)
Keep smile...
HasanCAD
« Reply #5 on: February 27, 2015, 02:58:49 AM »
Very great idea
It is able to add duct size? for example WxH.
And for fabrication, What about extracting parts data in excep sheet?
« Last Edit: February 27, 2015, 03:36:22 AM by HasanCAD »
Andrea
« Reply #6 on: February 27, 2015, 12:34:22 PM »
Hi HasanCAD,
SDUCT already have TEXT dimension for Ductwork.  :lmao:
I've added quantity duct length for each ductwork dimension included and quantity component
linked to a CSV file allowing approx estimation of project.  :-D
but no tag of peace since now because the objective is to standardize the double line ductwork desing first and help drafter to be more efficient.
Keep smile...
nirav
« Reply #7 on: March 02, 2015, 06:55:41 PM »
Hi Andrea,
Well done!!
 Is there any chance to put air flow rate formula in the code, so that one can see the difference in using different shapes and joints? No doubt, input flow rate will need to be assumed but the outlet rate could be calculated.
Cheers.
Andrea
« Reply #8 on: March 04, 2015, 12:56:28 PM »
It can be done...but unfortunatly..not on the next release.
to much work for now..
But I'll keep your suggestion :)
thank you.
Keep smile...
Andrea
« Reply #9 on: April 16, 2015, 11:16:52 AM »
Hi all,..
I'm trying to make dynamic offsets..for SDUCT.
it seem to work,..but I would like to know if maybe some of you know the good way to draw this kind of offset..
I mean,..what is the curve calculation of this. at the moment I use vl-offset function for easier way.
thank you.
Keep smile...
