Author Topic: UNDO command in vlisp  (Read 2141 times)
Lupo76
« on: February 22, 2015, 12:17:15 PM »
Hello everyone,
I need to use the following code within a reactor
(command "_undo" "1")
Unfortunately this is not possible in a reactor.
I then tried with
(vl-cmdf "_undo" "1")
but also in this case does not work: no error but does not perform the operation.
Do you have any idea?
Marc'Antonio Alessi
  • Marco
Re: UNDO command in vlisp
« Reply #1 on: February 22, 2015, 01:13:21 PM »
Maybe (vlr-undo-reactor data callbacks)?
Lupo76
« Reply #2 on: February 23, 2015, 02:50:50 AM »
I read here: http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-184F011B-8B61-4D3F-82F3-06A75C4459AE
but I did not understand how to use it.
I suspect that is not what I need.
I have made a reactor object:
(defun reactor_endmodify (notifier-reactor object-object parameter-list)
    (if (and (= (getvar "CMDNAMES") "BREAK")(= var T))
           (princ "\nDo not use the command 'BREAK' but use the command 'XXX'")
           (command "_undo" "1") ;<-----ERROR !!!!
This reactor has many lines of code and in some circumstances intercepts the start of the BREAK command and issues a message such as "Do not use the command 'BREAK' but use the command 'XXX'. This message should not appear every time it is used BREAK command but only in certain circumstances. To explain all the context is a bit difficult ....
Now I would like to use the UNDO command to cancel the operation of the BREAK command.
roy_043
  • BricsCAD 18
« Reply #3 on: February 23, 2015, 04:08:17 AM »
Lupo76
« Reply #4 on: February 23, 2015, 04:27:29 AM »
Try using a postprocess:
http://www.theswamp.org/index.php?topic=42826.5
Very Well!
the post that you indicated was open to me, but at that time I did not realize 100% anyway.
Today, however, is much clearer for me and it works!  :lol:
Thank You
Lupo76
« Reply #5 on: February 23, 2015, 04:32:28 AM »
Here is the correct code:
(vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "_.undo 1 ")
