Author Topic: Visibility States  (Read 1913 times)
bfred805
Visibility States
« on: February 20, 2015, 05:00:33 PM »
Hello, I have attached a block file that I am working on. I have all the visibilities working as desired minus the block attribute. How can I make this visible for all states? Currently, I right click > object visibility > Visible in all states.
I close block editor, and run ATTSYNC on block. Nothing appears.
Can anyone please help?
ChrisCarlson
Re: Visibility States
« Reply #1 on: February 23, 2015, 08:10:59 AM »
Works fine here, did you try deleting and re-inserting the block?
bfred805
« Reply #2 on: February 23, 2015, 12:34:52 PM »
I did. Something simple I overlooked. Here's a question I now have.
How is it possible to allow the user to insert a block size when inserting, and then have the tree symbol scale, but not the attribute text?
For example:
User specifies a 20' tree canopy. How to to scale symbols to 20 ft. but keep text at same size?
Thanks,
« Reply #3 on: February 23, 2015, 12:57:03 PM »
For example:
Thanks,
select only the tree linework and add a scale parameter to your dynamic block
ChrisCarlson
« Reply #4 on: February 23, 2015, 01:02:25 PM »
To keep it attributey, you should be able to remove the grip but keep it in the property window and set it to incremental sizing.
bfred805
« Reply #5 on: February 23, 2015, 01:17:07 PM »
For example:
Thanks,
I'm realizing there is more to it than a simple scale. Is there a way to keep the text aligned with the block which needs to scale from the centerpoint of the symbol?
