Author Topic: where are the shp files for hatch patterns stored?  (Read 2920 times)
« on: February 20, 2015, 04:59:30 PM »
I know I should know this....but where in world are the shp files stored for hatch patterns?
Is it compiled?  Can I add to it?
What is that file name...?
huiz
  • Certified Prof C3D
Re: where are the shp files for hatch patterns stored?
« Reply #1 on: February 20, 2015, 05:02:05 PM »
You can create your own .pat files and put them in the support file search paths.
I don't know if the common patterns are single files or included in the drawing. I think, once you load a custom one, it is included.
« Reply #2 on: February 20, 2015, 05:15:46 PM »
the real question is/was  where does
Infrastructure Studio store them?
I cant seem to find a PAT file under that application
« Reply #3 on: February 20, 2015, 05:24:52 PM »
C:\Users\USERNAME\AppData\Roaming\Autodesk\C3D 2015\enu\Support\Acad.pat
« Reply #4 on: February 20, 2015, 05:31:00 PM »
Thanks all for my poorly formed question...Just going crazy in circles trying to find where either
Maestro 5.1
or
stores their version of what appears to be autocad PAT file for area fills.....
tombu
  • ByLayer=>Not0
« Reply #5 on: February 25, 2015, 07:44:55 AM »
Maestro 5.1
or
Not familiar with either of those, but if they put hatch patterns in AutoCAD you can get the definitions with:
http://www.turvill.com/t2/free_stuff/getpat.lsp
GETPAT.LSP (c) 2001 Tee Square Graphics
    Version 1.01b - 1/22/2002
This routine may be used to extract hatch pattern data
from existing drawings when the .pat file containing
the original information is not available.
HTH,
Tom Beauford P.S.M.
Matt__W
  • I like my water diluted.
« Reply #6 on: February 25, 2015, 08:01:48 AM »
Maybe this will help next time... :whistling:
http://m.wikihow.com/Ask-for-Help
Autodesk Expert Elite
lamarn
« Reply #7 on: February 25, 2015, 08:57:56 AM »
PAT files are recognized if you put them in your current DWG drawing folder
« Reply #8 on: February 25, 2015, 08:59:43 AM »
As it turns out...those patterns are hard coded into that application....
so there is no support for adding PAT, or SHX files to it.
And that would explain why various searches of the directories revealed NO such files within the folders for that application.
And I was holding out hope that maybe, just maybe it shared other installed autodesk resources.  (fat chance!)
ChrisCarlson
« Reply #9 on: February 25, 2015, 09:58:46 AM »
I've not used those programs but the hatch patterns they use shouldn't be too difficult to mimic.
« Reply #10 on: February 25, 2015, 10:04:16 AM »
They are mostly EXACTLY the same patterns as Autocad.
They are NOT (PAT or SHX) files.
They CAN NOT be added to or deleted from.
They are embedded in the application code.
I have been sent and told approximately what I must do using a 'work around' to take my desired pattern object(s) and convert it to XML file format
and then I will be able to do area fills with that data as part of what they call 'advanced stylization', although it seems to be very primitive.
The price of OPENSOURCE.....and of course a similar feature DOES exists and is better supported in the pay version.
