Author Topic: create a block through a image  (Read 7626 times)
Fabricio28
« on: February 20, 2015, 07:29:23 AM »
Hi guys,
I'm trying to create a block with a image.
Anybody Can help me doing that, please?
 :-D
huiz
  • Certified Prof C3D
Re: create a block through a image
« Reply #1 on: February 20, 2015, 10:28:19 AM »
If you insert the image in the block editor then you must have the image somewhere available for everybody who opens the drawing.
Else you can copy the image from Paint or so and paste it in AutoCAD, then it becomes an OLE and the image will be kept inside the drawing.
« Reply #2 on: February 20, 2015, 10:44:22 AM »
OR, there is some routine posted here at swamp that will read the pixels and turn it into autocad objects (points)
Fabricio28
« Reply #3 on: February 20, 2015, 11:28:43 AM »
Thank you guys,
This routine sounds to bem great!
When can I find it?
Regards
« Reply #4 on: February 20, 2015, 11:51:37 AM »
looks like the links I'm finding with search are broken....
http://www.cadstudio.cz/imgconvert
« Reply #5 on: February 20, 2015, 02:08:01 PM »
Here you go  8)
Windows 10 x64 - AutoCAD /C3D 2020
Fabricio28
« Reply #6 on: February 20, 2015, 09:42:46 PM »
Fantastic Ron,
I loved it!  :-D
It's perfect, excellent job!
The logo_color is just a test?
The black one is beatiful.
Regards
« Reply #7 on: February 21, 2015, 12:45:39 AM »
Fantastic Ron,
I loved it!  :-D
Regards
I used adobe illustrator to create. Enjoy :)
Fabricio28
« Reply #8 on: February 21, 2015, 03:53:03 PM »
Fantastic Ron,
I loved it!  :-D
Regards
That's cool!!  :-D
Thank you
Fabricio28
« Reply #9 on: January 02, 2018, 07:14:29 AM »
Here you go  8)
Hello Everyone!!
Happy New Year.
This year believe in yourself and achieve everything you deserve.
I need a help to convert the image as autocad block.
Could you help me, please?
Thanks in advance.
Fabrício
MSTG007
« Reply #10 on: January 02, 2018, 07:23:44 AM »
Could I ask what are your steps to do this with Adobe Illustrator?
I usually play around with vectormagic...
Autodesk Infrastructure Design Suite 2019
Fabricio28
« Reply #11 on: January 02, 2018, 07:40:24 AM »
Hi friend
Unfortunately don't know how to use Abode Illustrator.
Fabrício
« Reply #12 on: January 02, 2018, 10:22:59 AM »
Here you go .. although you'd get a much better result if you took some time to trace it. You could use THIS to trace your letters assuming you have the correct fonts installed.
MSTG007
« Reply #13 on: January 02, 2018, 10:28:34 AM »
now that is interesting...
Fabricio28
« Reply #14 on: January 02, 2018, 12:30:22 PM »
Hi my old friend Ron,
Thank you very much for the help.
Fabrício
