Author Topic: Derp Moment  (Read 5888 times)
ChrisCarlson
Derp Moment
« on: February 19, 2015, 04:29:31 PM »
Where am I messing up this block? I'm trying to get a simple rotation about the center point but it doesn't seem to be cooperating.
Re: Derp Moment
« Reply #1 on: February 19, 2015, 05:28:21 PM »
Remove the Distance2 parameter from the Rotation's selection set. It then works correctly. Oh, you should also set the INSBASE to 0,0,0 as well.
« Last Edit: February 19, 2015, 05:53:57 PM by Jeff_M »
ChrisCarlson
Re: Derp Moment
« Reply #2 on: February 20, 2015, 07:58:11 AM »
Thanks, is there a better way to stretch both sides?
Distance 2 is chained to distance 1 with an angle offset of 180 degrees.
Re: Derp Moment
« Reply #3 on: February 20, 2015, 08:55:55 AM »
You still use the chained Distance2, just omit it from the Rotation Selection Set....I think it is automatically included when you select the Distance1 since they are linked.
To do this, right-click the Rotate Action icon, go to the Action Selection Set, then select Modify Selection Set, then type in R, Enter, now select the Distance2 parameter, Enter.
« Last Edit: February 20, 2015, 09:01:34 AM by Jeff_M »
ChrisCarlson
Re: Derp Moment
« Reply #4 on: February 20, 2015, 09:06:26 AM »
Wow, that was the fix. Don't quite understand the why just yet, I'll have to look into it sometime. Thanks!
