Author Topic: Significant commandline lag  (Read 5274 times)
alanjt
  • Standby for witty remark...
« on: February 18, 2015, 08:58:17 AM »
Running Civil 3D 2013.
I've noticed that, after a while of working in a file, running various lisp routines, etc., thing will get a bit laggy. Selection seems slower, etc. If I close the commandline, everything works fine. It's almost as if I'm allowed a certain number of executed lisp routines, then the commandline slows everything down. At this point, I close the commandline, hit f2, and go back to work, slightly annoyed.
Has anyone had any experience with this?
Dropbox
Re: Significant commandline lag
« Reply #1 on: February 18, 2015, 01:33:57 PM »
it's just time dialation ...you are working at or near the speed of light
slow down a little and everything will return to normal
alanjt
« Reply #2 on: February 18, 2015, 02:32:34 PM »
I'm slightly depressed at how, aside from closing the commandline, that's actually the best solution.
I know this stems from the commandline being completely reconfigured. I never noticed this with 2012 or older.
Dropbox
« Reply #3 on: February 18, 2015, 04:42:44 PM »
have to ask what OS are you running, and how much ram and is your page file 'fixed' or windows managed?
alanjt
« Reply #4 on: February 18, 2015, 04:52:18 PM »
Windows 7
16GB
I don't understand the third question.
Dropbox
« Reply #5 on: February 18, 2015, 05:00:07 PM »
see attached....
wonder if you have some form of memory leak?
check task manager/performance monitor to see where your memory is being allocated and to what processes
Rob...
« Reply #6 on: February 19, 2015, 07:40:32 AM »
Just a stab in the dark here:
Does it make a difference if it is docked or not?
CAD Tech
lamarn
« Reply #7 on: February 19, 2015, 08:21:07 AM »
Same here, it seems Autocad is becoming slower and slower with every new release..
We have a issue with netwerk speed and Autocad commands..
Rob...
« Reply #8 on: February 19, 2015, 08:27:37 AM »
I think that is a different issue from the OP. Yours is probably due to hardware. Newer versions will tend to be slower on borderline spec hardware or the info center is eating up bandwidth.
CAD Tech
Matt__W
  • I like my water diluted.
« Reply #9 on: February 19, 2015, 08:52:23 AM »
I've heard issues with dual monitors and windows being docked on the primary vs. secondary makes a difference sometimes.
Still don't understand that one...  :|
Autodesk Expert Elite
dgorsman
« Reply #10 on: February 19, 2015, 10:19:54 AM »
Primary vs. secondary monitor has to do with hardware acceleration - unless the desktop was "spanned" across both monitors there was no hardware acceleration on the second monitor.  Likely the same thing if the command line (as a separate palette) is undocked and on the second monitor.  That applied under XP, not certain if it still applies with more recent OS/DirectX/hardware combinations.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
alanjt
« Reply #11 on: February 19, 2015, 12:05:16 PM »
see attached....
acad, outlook, chrome (can be a memory hog), dropbox, nothing really out of the norm.
It does not. I tried that since that was supposed to be a solution for lag with the properties palette (which I have to keep closed), but it made no difference.
acad shows up in main display window and commandline is docked.
Dropbox
dgorsman
« Reply #12 on: February 19, 2015, 02:07:17 PM »
Not a solution but out of curiosity, does the lag start around the time the command line history hits the maximum lines it stores?
Is this strictly with running LISP routines, or is it commands and operations in general?  If the former, there could be some leftover references (previous settings, temporary lists, etc.) which aren't cleaned up properly.
try {GreatPower;}
   finally
      {MasterBasics;}
alanjt
« Reply #13 on: February 19, 2015, 03:01:32 PM »
That's an interesting thought.
Once it starts, it has a lag for everything. LISP being the cause is nothing more than a wild guess.
It's as if I've hit my quota of executed commands, then it gets laggy (while commandline is on). Pretty much, after 5-10 minutes of working on a job, I'll have to close the commandline.
While selection does incur a lag, the commandline (printing text or entering in) becomes sluggish. I was plotting a few easements in my base file the other day, when I noticed it couldn't keep up with me and completely exited out of the core civil 3d line by bearing command.
Dropbox
« Reply #14 on: February 19, 2015, 04:49:32 PM »
Does a (gc) have any effect? - Just a stab in the dark.
