Author Topic: xref file  (Read 2312 times)
Fabricio28
xref file
« on: February 13, 2015, 07:05:28 AM »
Hi guys,
I've renamed the folder of my files:
(\\BRSPHBT01\Dados\PRE-HABITARTE\AUTOCAD) to
 (\\BRSPHBT01\Dados\DEAP\AUTOCAD)
And I lost the main project reference. There is a way to update the new path?
Just change PRE-HABITARTE to DEAP.
Regards
Fabricio28
Re: xref file
« Reply #2 on: February 13, 2015, 07:16:33 AM »
Rob...
Re: xref file
« Reply #3 on: February 13, 2015, 07:26:19 AM »
You can re-path it manually at Saved Path or...
They hid the button to browse to the new location behind these three little dots:
CAD Tech
Fabricio28
Re: xref file
« Reply #4 on: February 13, 2015, 07:37:34 AM »
Thank you very much.
I couldn't edit the new path, I used found at.
Thank you
Fabricio28
Re: xref file
« Reply #5 on: February 13, 2015, 09:17:44 AM »
Hello again,
Is there any way to explode xref file?
Because I need to send some files and I don't wanna send all my main project.
Re: xref file
« Reply #6 on: February 13, 2015, 09:26:10 AM »
A) don't include the XREFS <they will cry>
B) wblock to a new file ONLY the information you want to include....and XREF or insert that as block
C) PLEASE do not BIND or EXPLODE your XREFS  did I say please?
Fabricio28
Re: xref file
« Reply #7 on: February 13, 2015, 09:30:05 AM »
I didn't do anything yet.
I wanna send a file without any reference. Because I don't wanna send the main project.
Rob...
Re: xref file
« Reply #8 on: February 13, 2015, 09:32:26 AM »
You could bind your XREFs and explode so that can delete the stuff you don't want, but you need to consider what the recipient is going to do with the file.
CAD Tech
Rob...
Re: xref file
« Reply #9 on: February 13, 2015, 09:41:35 AM »
Just detach the XREF and "Save As".
CAD Tech
dgorsman
Re: xref file
« Reply #10 on: February 13, 2015, 10:34:54 AM »
Reference Manager for mass updating of XREF paths.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Fabricio28
Re: xref file
« Reply #11 on: February 13, 2015, 12:14:13 PM »
Thank you worked excellent!!
Regards
