Author Topic: [vb.net] how to get the value of autocad text window list custom object  (Read 2162 times)
nasaman
  • Mosquito
« Last Edit: February 13, 2015, 03:58:40 AM by nasaman »
dgorsman
Re: [vb.net] how to get the value of autocad text window list custom object
« Reply #1 on: February 13, 2015, 10:29:15 AM »
Doesn't work that way.  The information is associated with the object, the command history is just reporting on what that command found.
You'll need a way to query the object for the requested information, which will vary based on what the object is.  Note that it may not be exposed for your use.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Keith Brown
« Reply #2 on: February 13, 2015, 12:56:36 PM »
1. Turn your Log file on.
2. list the object.
3. Turn your Log file off.
4. Parse the file.
It is clunky, but it will work as long as you know what you are looking for.
