Author Topic: Discussion: Concatenations of car and cdr  (Read 5963 times)
« Reply #15 on: April 22, 2005, 04:45:22 PM »
Quote from: TimSpangler
doesn't (nth Pos List) give you that same only with an expected resualt
(setq r '(a b c d e f g))
(nth 4 r)
d
Is this way no good?  This is usually how I get there from here.
What?
You had better check your results. :shock:
daron
« Reply #16 on: April 22, 2005, 04:48:21 PM »
Hahahaha. I didn't see that. Pssst! Tim, 'e' would be the expected result. ROFL.
« Reply #17 on: April 22, 2005, 04:50:03 PM »
Maybe it's a customized nth function. :)
daron
« Reply #18 on: April 22, 2005, 04:50:52 PM »
Party pooper.
« Reply #19 on: April 22, 2005, 04:55:11 PM »
Tim,
nth is what i use most of the time.
When it gets beyond car cdr I look in the book, big green tab hangin out.  :)
