Author Topic: Is it possible to sort Layers in Hatch Dialogue Alphabetically?  (Read 3001 times)
ROBBO
« on: February 11, 2015, 07:56:23 AM »
See example attached with Layers in random order.
Kr. Robbo
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
Re: Is it possible to sort Layers in Hatch Dialogue Alphabetically?
« Reply #1 on: February 11, 2015, 08:54:34 AM »
mine already are...
check
MAXSORT
ROBBO
« Reply #2 on: February 11, 2015, 09:10:15 AM »
mine already are...
check
MAXSORT
Hello mjfarrell,
That was the first thing I tried, but no joy. It is set to 1000. when I change to 10000 - no change.
Kr. Robbo.
Oscar Wilde
« Reply #3 on: February 11, 2015, 09:20:02 AM »
from help file..
Sets the maximum number of items such as file names, layer names, and block names that are sorted alphabetically in dialog boxes, drop-down lists, and palettes.
MAXIMUM SETTING
32767
you went about 1/3 of MAX
« Reply #4 on: February 11, 2015, 09:29:54 AM »
MAXSORT does not alphabetize my layers in the hatch dialog.
« Reply #5 on: February 11, 2015, 09:36:17 AM »
then the help file is wrong and
the MAXSORT function is broken - as stated that IS what it is supposed to control
OR
If the total number of items, also called named objects, exceeds this value, no items are sorted.
ROBBO
« Reply #6 on: February 11, 2015, 09:47:47 AM »
OR
I have looked in to this, but my drawing is a blank template with default layers and blocks with in it, therefore should not be a problem. Just frustrating when hatching and want to select a layer. BTW I am using AutoCAD 2014.
All the best, Robbo.
Oscar Wilde
« Reply #7 on: February 11, 2015, 09:58:11 AM »
one could always set the desired layer current FIRST...and not do it in the layer dialog...and then send a hate mail to autodesk
« Reply #8 on: February 11, 2015, 10:09:01 AM »
Yup .. doesn't work.
« Reply #9 on: February 11, 2015, 10:14:29 AM »
so glad I don't work for autodesk.....
on the other hand....they should hire me to help kick the programmers's collective behinds into fixing all these little annoying
f'ups that just don't work as they should.
The users would most likely love me,
while the programmers would plot my demise...
The stock holders would also love me...as a better product would build more loyal customers...
« Reply #10 on: February 11, 2015, 10:21:52 AM »
alternate # 3
use HPLAYER to set hatch layer in advance
« Reply #11 on: February 11, 2015, 10:39:44 AM »
Further research shows....FINALLY  FIXED
IF  you are using R2015
Layer sort
Layer lists are now displayed using natural ordered sort. For example, the layer names 1, 4, 25, 6, 21, 2, 10 are sorted as 1,
2, 4, 6, 10, 21, 25 instead of 1, 10, 2, 25, 21, 4, 6. Natural ordered sort applies to all layer lists including the Hatch Editor
Ribbon tab and Quick Select just to name a few. You can restore the ASCII sort used in previous releases by changing the
new SORTORDER system variable to 0.
ROBBO
« Reply #12 on: February 12, 2015, 02:06:50 AM »
Answer from Autodesk Enterprise Priority Support:
"Thank you for creating a case with Autodesk Enterprise Priority Support.
It appears that you are using the classic version of the hatch command (eg HPDLGMODE=1). This dialog box behaves differently from the ribbon version of the command, in that it does not regard the layer settings for your drawing.  In the ribbon version of the command, it will show layer settings from the layer dialog box.  For example, if you have a filter active, the ribbon will show you the layers included in the filter.  The classic Hatch dialog ignores these filters and "does its own thing" with regard to sorting.
I hope this helps! Let me know if you have any additional questions. "
Oscar Wilde
