That's a lisp question! Not sure yet what you're looking for though. There are many ways to load lisp routines. Acad.lsp will load them when AutoCAD opens. Acaddoc.lsp will load them when each drawing opens. Most routines that aren't used as often can be auto loaded as needed. Many ways to do that. Are you going to type the commands or put them in the CUI as macros?
I think it just type the commands not put them in the CUI.
I am making the little function about processing the drawing in ACAD and output the result to excel files.
But when i finish the program , i think assamle all the code in one file is not good idea.
So that i want to replace some functions like general function, parameters ,.etc into other files.
Because it would be much clear in every time i edit it.
My idea is that:
when i load the main program, then load the parameters.
But some function or parameters would not be loaded until i called.
Thanks!
