Author Topic: Wipeout moved to back in dynamic block  (Read 7080 times)
HasanCAD
« on: February 08, 2015, 09:57:32 AM »
I created a a dynamic block with a wipeout the dynamic block is OK, but when stretching the wipeout moved to back and lins apeare.
snownut2
  • Bricscad 22 Ultimate
Re: Wipeout moved to back in dynamic block
« Reply #1 on: February 08, 2015, 05:27:51 PM »
I would say that by stretching the lines, they where rewritten in the database putting them on top of the wipeout.
ChrisCarlson
« Reply #2 on: February 09, 2015, 08:12:41 AM »
If you regen after the stretch does the wipeout correct itself?
HasanCAD
« Reply #3 on: February 09, 2015, 10:30:53 AM »
NO
ChrisCarlson
« Reply #4 on: February 09, 2015, 12:08:58 PM »
The issue is related to the array action, the wipeout is working, however it's set above the background but below the new array. I'm not certain there is a "fix"to this, aside from removing the wipeout and setting the center drain to be static and stretch from both ends with an array for the two slots on each end.
« Reply #5 on: February 09, 2015, 12:13:46 PM »
suggest you try using elevation on objects to control position rather than draw order
draw the base stuff at 0
next stuff a 1
next at 2
next at 3
place wipe out at elevation to remove those things below it....2.5 or what ever makes sense
The above doesn't work..
So why not draw that center portion as fixed elements?
And allow the array/mirror of the other grate objects occur without need of any wipe out?
« Last Edit: February 09, 2015, 12:54:25 PM by mjfarrell »
