Hello everyone,
I attach a file dwg where there is the same block with a different orientation.
In the properties of the scale values XY and Z and rotation are the same for both blocks.
Even the values in (entget) are identical for both blocks.
However, the two blocks in the drawing are oriented in a different way.
The block of red color should be the one with the correct rotation.
Maybe I could fix this, using BATTMAN, however it seems that this command does not exist on the command line.
I also thought about using SYNCATT, but unfortunately this affects all the blocks that have the same name.
I wish I could fix a single block (eg. Selected with (setq obj (car (entsel)))) without affecting the other.
Have you any suggestions?
Thanks in advance.
