Author Topic: Add editable text component to alignment label style (not override)  (Read 2524 times)
Dave M
Does anyone know how to add editable text to a label style without doing an override?  I would like to be able to add a description to my elevation label component similar to the "EG" in the vertical label without having to create multiple styles for every description, and without having to do a label text override.
Thanks!
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
Re: Add editable text component to alignment label style (not override)
« Reply #1 on: January 29, 2015, 03:22:10 PM »
good luck on that....
as you have by now discovered...even IF you attempt to embed an attribute within the label style
once it inside the label wrapper....it ceases to function as a normal attribute
however....you could work back to front...
USE a POINT LABLE for these instead you can set it to prompt you for descriptions!
Side bonus....they can then also be exported and or placed in tables for construction staking purposes.
Around here I've convinced the users that points are smarter to use than labels for that vary reason.
BlackBox
« Reply #2 on: January 29, 2015, 05:09:17 PM »
I still wish DBText, MText, and MLeaders (with ContentType.MTextContent) supported C3D Expressions as they do Fields currently.  :|
alanjt
  • Standby for witty remark...
« Reply #3 on: January 30, 2015, 08:47:02 AM »
And that Fields worked in c3d labels.
Dropbox
