Author Topic: how can i search thru a selection set for a specific word  (Read 2086 times)
andrew_nao
« on: January 28, 2015, 03:48:44 PM »
hi all.
I lost all my bookmarks so im in search of all the functions and posts all over, that i once had :(
i know this post exists in here cause i had it book marked so if someone can point me in the right direction
i need a refresher on how to search thru a selection set for a specific line of text.
as always any help is appreciated
Re: how can i search thru a selection set for a specific word
« Reply #1 on: January 28, 2015, 05:38:17 PM »
An easier way might be to filter the initial selection, e.g.:
  1. (ssget "_X" '((0 . "TEXT") (1 . "*specific line of text*")))
andrew_nao
« Reply #2 on: January 29, 2015, 09:55:32 AM »
thanks lee however if there is more than 1 on the screen i need to be able to select the right one.
ive searched this forum for 4 hours and i cannot find that post now.. :( do posts get dropped off after a certain amount of time?
Gasty
« Reply #3 on: January 30, 2015, 10:33:04 PM »
How do you discriminate the "right one" from the others? The "solution" from Lee find any text, anywhere in the drawing with a match of the string in the filter, so if you need to narrow the search please tell us how.
Gaston Nunez
« Last Edit: January 30, 2015, 10:38:14 PM by Gasty »
ymg
« Reply #4 on: January 31, 2015, 04:12:46 AM »
andrew_nao,
You could search with google and restrict the search to theSwamp only.
Example:
andrew_nao site:theswamp.org
« Reply #5 on: January 31, 2015, 05:13:55 AM »
andrew_nao,
Example:
yep,
About 526 results (0.66 seconds)
« Reply #6 on: January 31, 2015, 01:33:23 PM »
Maybe create a Google account and use Chrome. Sign into your browser and your shortcuts will not get lost in the future ( unless you delete them ).
