Author Topic: Navisworks 2015 - Selection set based on pipe diameter - No Objects Found  (Read 9478 times)
Matt__W
  • I like my water diluted.
In Navisworks I see a category for REVIT TYPE and a property for PIPE DIAMETER but when I try to find all pipes greater than 2" in diameter Navisworks doesn't find anything and I know there for certain there are LOTS of pipes that meet this requirement. Is there a setting I should check in the Export options in Revit or something in the Navisworks options??
Autodesk Expert Elite
suggest you specify a type....
dgorsman
I have the same problem with other non-Revit sources, in that the pipe size is presented as a text value rather than a number.  Could that be the problem?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
from my experience the better one knows the data being search, the better the results....that my seem obvious, but it wasn't to me at first
some suggest selecting and element of type, and looking at the properties reported to construct search criteria
Matt__W
Would anyone who ACTUALLY USES Navisworks care to chime in?   :roll:
JNieman
Have you tried turning it off and back on again?
 :-D
so I select an item from REVIT model
using selection inspector I get that object properties....
then I can search for items with those properties
As the model I used is 'unknown' to me  I must use this method
Cathy
I see that you are searching Selected Paths Only.  Did you try searching Below Selected Paths?  Or using the Default?
It's not a mm/inch problem, is it?
Navisworks won't give you a > sign for a condition if it's not a numeric field. So that's not it.
