Author Topic: Vertical cross section of a Tunnel pipe problem  (Read 11715 times)
ekoneo
« on: January 27, 2015, 10:12:27 AM »
Hi all,
I prepare a small tunnel corridor model. The radius is 4m.
The tunnel's profile has a %5 vertical profile slope. I finished the model. I draw all sections.
Then I try something. I increased the slope up to %60. I know this impossible condition for a tunnel construction.
But I wonder that what happens on the model.
All corridor sections are consisted vertically. So the tunnel radious goes smaller.
However the tunnel radious becomes smaller, the section drawings shows the radious 4m.
How can I draw the sections that are perpendicular to the profile slope?
Re: Vertical cross section of a Tunnel pipe problem
« Reply #1 on: January 27, 2015, 10:19:20 AM »
Hi all,
I don't think your models shows what you think it does....
Let me test here...is the tunnel bottom flat, than an arched section?
« Reply #2 on: January 27, 2015, 10:39:46 AM »
here...
ekoneo
« Reply #3 on: January 27, 2015, 10:42:11 AM »
I try to sketch it below
« Reply #4 on: January 27, 2015, 10:43:52 AM »
how or what did you use for your circular assembly?
there are at least two good ways- sub assembly by polyline....or generic links....have fun working out the slopes for that one!
ekoneo
« Reply #5 on: January 27, 2015, 10:58:13 AM »
I increased your profile slope. I make the section interval distance 5m.  I rebuilt your corridor. Then I upload here.
ekoneo
« Reply #6 on: January 27, 2015, 11:05:01 AM »
I made it with subassembly from a polyline.
« Reply #7 on: January 27, 2015, 11:05:33 AM »
Move my sample line to any station and the cross section is normal....i.e. I don't see any problem with the model
« Reply #8 on: January 27, 2015, 11:07:04 AM »
if one uses the DRIVE command it does 'appear' to be wrong...however that is just a perception.
ekoneo
« Reply #9 on: January 27, 2015, 11:29:04 AM »
The problem is cross sections shows normal. But corridor sections are not perpendicular to the profile line. They are perpendicular to Y axis.
Although radious decrease, the crosssection shows normal. I need the cross section that is perpendicular to the road profile line.
« Reply #10 on: January 27, 2015, 11:34:58 AM »
sounds like you would be wanting to use EXTRUDE and SLICE to get sections from a solid...not roadway sections..
or provide ample of what you have, and what you think you want...
I'm pretty sure the software is performing as expected...
ekoneo
« Reply #11 on: January 27, 2015, 12:03:36 PM »
I atached a photo from your corridor. On vertical side tunnel becomes thin. But Tunnel corridor width and height should be constant.
« Reply #12 on: January 27, 2015, 12:27:38 PM »
oblique/vertical exaggeration  i.e. Don't trust your eyes on this one
« Reply #13 on: January 27, 2015, 12:31:41 PM »
from side view................same size....
ekoneo
« Reply #14 on: January 28, 2015, 02:54:54 AM »
Hi mjfarrell,
I think about your last post during a long time.
Then I had a question myself..
I try to sketch it.
In the sketch,
The train's height is not parallel to your measurement direction. If the slope increase the tunnel height become smaller than the train's height (theorically).
