Hi All,
I am trying to repath all the xrefs (including "AcDbRasterImage") in multiple files using Objectdbx and autolisp
I have more or less the following code for dealing with "AcDbRasterImage"s
; Set up our paths.
(setq
path_base "Q:\\Trial\\problematic2\\"
(setq
dbx_master (
vla-getinterfaceobject(vlax-get-acad-object)
(strcat "ObjectDBX.AxDbDocument." (substr (getvar 'AcadVer) 1 2))
(foreach drawing (vl-directory-files path_base "*.dwg")
(setq checkIfOpenMaster (vl-catch-all-apply 'vla-open (list dbx_master (strcat path_base drawing))))
(princ (strcat "Got File '" path_base drawing "\n"))
(if (= (type checkIfOpenMaster)'VL-CATCH-ALL-APPLY-ERROR)
(princ (strcat "Master File '" (strcat path_base drawing) "' cannot be opened \n"))
; Loop though each layer to search for xref in formats other than dwg
(setq LOCol (vla-get-Layouts dbx_master))
(princ (strcat "Got layouts in File '" path_base drawing "\n"))
(vlax-for LO LOCol
(vlax-for Obj (vla-get-Block LO)
(= (vla-get-ObjectName Obj) "AcDbRasterImage")
(princ "Inner Loop \n")
(setq image (vla-get-ImageFile Obj))
(princ "Got Image \n")
(setq imageName (vl-filename-base image))
(princ "Got Image Name \n")
(setq imageExtn (vl-filename-extension image))
(princ "Got Image Extn \n")
(vla-put-ImageFile Obj (strcat "./" path_processed_other_refs (vl-filename-base image) imageExtn))
But then it crashes when I encounter a file containing an image with status "Not Found". How can I implement the equivalent of vl-catch-all-apply....thing for that?
Additionally, is there a general way for me to process these non-dwg format xrefs? For the batch of AutoCAD drawings that I have to process, there are also PDFs, .doc(x)s, .xls(x) etc as xrefs.
Thanks a lot in advance.
