Author Topic: Find Min Y Coordinate on a Polyline and insert block  (Read 6177 times)
pedroantonio
« on: January 23, 2015, 11:52:26 AM »
Hi . After a little search i find a lisp code in this page http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/min-y-coordinate-on-a-polyline/td-p/2601957
I want a litle help to do some changes. Tis lisp finds  Min Y Coordinate on a Polyline.
I want to find the  Min Y Coordinate on a Polyline and then insert automaticaly a  block in point (0.00,y). The y=  Min Y - 14 meters
  1. (defun C:test ()
  2. ; for Minimum Y coordinate of an object
  3. (vl-load-com); just in case
  4. (vlax-ename->vla-object (car (entsel)))
  5. 'LL 'UR
  6. )
  7. (rtos (cadr (vlax-safearray->list LL)) 2 2)
  8. )
  9.
  10. ;Insert automatocaly block in (0.00,[Minimum Y - 14.00]) <-- i don't now haw to give this !!
  11. (setq dt1 (getpoint "\n inset block  (0.00,[Minimum Y - 14.00]) :"))
  12.  (command "insert" "*block" dt1 "" "0")
  13. )
  14.
pedroantonio
Re: Find Min Y Coordinate on a Polyline and insert block
« Reply #1 on: January 23, 2015, 12:16:45 PM »
I am almost there but something is missing .I dont't know how to give the coordinate
  1. (defun C:test ()
  5. 'LL 'UR
  6. )
  8. (setq y (- 14 (cadr (vlax-safearray->list LL)))))
  9. (setq dt1 (0.00,y))
  10.  (command "insert" "*block" dt1 "" "0")
  11. )
  12.
  13.
Tharwat
  • Hypersensitive
« Reply #2 on: January 23, 2015, 12:54:42 PM »
Firstly change the Block name as per yours .
Secondly , is this the one you are after ?
  1. (princ "\n Select LWPolyline ")
  2. (if (setq o (ssget "_+.:S" '((0 . "LWPOLYLINE"))))
  3.     (list
  4.       '(0 . "INSERT")
  5.       (cons 2 "BlockName")
  6.       (cons
  7.         10
  8.         (list 0.
  9.               (- 14
  10.                  (cadar (vl-sort (mapcar 'cdr
  11.                                          (vl-remove-if-not
  12.                                            '(lambda (p) (eq (car p) 10))
  13.                                            (entget (ssname o 0))
  14.                                          )
  15.                                  )
  16.                                  '(lambda (j k) (< (cadr j) (cadr k)))
  17.                         )
  18.                  )
  19.               )
  20.               0.
  21.         )
  22.       )
  23.     )
  24.   )
  25. )
  26.
  27.
  28.
pedroantonio
« Reply #3 on: January 23, 2015, 01:05:31 PM »
hi Tharwat . I try your code but i use polyline not LWPOLYLINE !!!
Tharwat
  • Hypersensitive
« Reply #4 on: January 23, 2015, 01:09:01 PM »
Remove the LW before the object name Polyline and try again , otherwise upload a sample drawing showing before and after with the block that to be inserted .
pedroantonio
« Reply #5 on: January 23, 2015, 01:11:35 PM »
i change the code to
(defun C:test ()
(princ "\n Select Polyline ")
(if (setq o (ssget "_+.:S" '((0 . "POLYLINE"))))
  (entmake
    (list
      '(0 . "INSERT")
      (cons 2 "*pindiat")
      (cons
        10
        (list 0.
              (- 14
                                         (vl-remove-if-not
              0.
i put the lisp in the same folder with the block but the block didn't insert  :-o
Tharwat
  • Hypersensitive
« Reply #6 on: January 23, 2015, 01:16:24 PM »
If you want to insert the block from outside the drawing , you should use the insert command , that's if the insertion point is taken correctly as we have retrieved it with the codes .
pedroantonio
« Reply #7 on: January 23, 2015, 01:25:13 PM »
How to do it like this !!
(defun C:test ()
  (entmake
    (list
      '(0 . "INSERT")
      (cons 2 "pindiat")
      (cons
        10
        (list 0.
              (- 14
                                         (vl-remove-if-not
              0.
 (command "insert" "*pindiat" dt1 "" "0")
Tharwat
  • Hypersensitive
« Reply #8 on: January 23, 2015, 01:53:12 PM »
My program still using LWPOLYLINE .
(defun c:Test (/ o path)
  (if (and (setq o (ssget "_+.:S" '((0 . "LWPOLYLINE"))))
           (setq path (findfile (strcat (getvar 'DWGPREFIX) "pindiat.dwg")))
      (command
        "_.-insert"
        path
        nil
      (if (tblsearch "BLOCK" "pindiat")
        (entmake
          (list
            '(0 . "INSERT")
            (cons 2 "pindiat")
            (cons
              10
              (list
                0.
                  14
                                          (vl-remove-if-not
                0.
  (if (not path)
    (alert "Block name is not found in Directory !!")
efernal
« Reply #9 on: January 23, 2015, 01:54:57 PM »
  1. (DEFUN c:test (/ dxf pline ymin)
  2.   (IF (AND (SETQ pline (CAR (ENTSEL "\n-> Select POLYLINE entity : ")))
  3.            (= (CDR (ASSOC 0 (SETQ dxf (ENTGET pline)))) "POLYLINE")
  4.            (MEMBER (CDR (ASSOC 70 dxf)) '(0 1 128 129))
  5.       )
  6.     (IF (TBLSEARCH "BLOCK" "PINDIAT")
  7.       (PROGN (SETQ ymin 0.0)
  8.              (WHILE (SETQ pline (ENTNEXT pline))
  9.                (IF (= (CDR (ASSOC 0 (SETQ dxf (ENTGET pline)))) "VERTEX")
  10.                  (IF (< (CADR (CDR (ASSOC 10 dxf))) ymin)
  11.                    (SETQ ymin (CADR (CDR (ASSOC 10 dxf))))
  12.                  )
  13.                )
  14.              )
  15.              (ENTMAKE (LIST (CONS 0 "INSERT")
  16.                             (CONS 2 "PINDIAT")
  17.                             (CONS 10 (LIST 0.0 ymin 0.0))
  18.                             (CONS 41 1.0)
  19.                             (CONS 42 1.0)
  20.                             (CONS 43 1.0)
  21.                             (CONS 50 0.0)
  22.                             (CONS 210 (LIST 0.0 0.0 1.0))
  23.                       )
  24.              )
  25.       )
  26.       (ALERT "Error: No block PINDIAT definition...")
  27.     )
  28.     (PRINC "\n-> Not a valid POLYLINE...")
  29.   )
  30.   (PRINC)
  31. )
  32.
e.fernal
pedroantonio
« Reply #10 on: January 23, 2015, 02:01:30 PM »
I use the two codes and efernal and Tharwat (I change LWPOLYLINE to POLYLINE ) but the block didn't insert .My block is in folder c:\ dwg
efernal
« Reply #11 on: January 23, 2015, 02:02:08 PM »
  1. ;; BETTER...
  2.
  3. (DEFUN c:test (/ dxf pline ly)
  4.   (IF (AND (SETQ pline (CAR (ENTSEL "\n-> Select POLYLINE entity : ")))
  5.            (= (CDR (ASSOC 0 (SETQ dxf (ENTGET pline)))) "POLYLINE")
  6.            (MEMBER (CDR (ASSOC 70 dxf)) '(0 1 128 129))
  7.       )
  8.     (IF (TBLSEARCH "BLOCK" "PINDIAT")
  9.       (PROGN (SETQ ymin 0.0)
  10.              (WHILE (SETQ pline (ENTNEXT pline))
  11.                (IF (= (CDR (ASSOC 0 (SETQ dxf (ENTGET pline)))) "VERTEX")
  12.                  (SETQ ly (APPEND ly (LIST (CADR (CDR (ASSOC 10 dxf))))))
  13.                )
  14.              )
  17.                             (CONS 10 (LIST 0.0 (APPLY 'MIN ly) 0.0))
  18.                             (CONS 41 1.0)
  19.                             (CONS 42 1.0)
  20.                             (CONS 43 1.0)
  21.                             (CONS 50 0.0)
  23.                       )
  24.              )
  25.       )
  27.     )
  29.   )
  30.   (PRINC)
  31. )
  32.
e.fernal
pedroantonio
« Reply #12 on: January 23, 2015, 02:05:25 PM »
no give me this
pedroantonio
« Reply #13 on: January 23, 2015, 02:09:20 PM »
Here is the files i use
« Reply #14 on: January 23, 2015, 02:13:12 PM »
no give me this
First off you have to know what type of objects you are selecting .. you say one thing then your drawing contradicts it.  :?
