Author Topic: Dwgprefix set as projectname 'current'  (Read 2824 times)
lamarn
« on: January 21, 2015, 04:22:06 PM »
I am trying to set my current DWG supported
as projectname:current with DWGprefix as the registry entry.
So if it is loaded at opening of dwg i have a support directory at the same level.
I thought this might be handy for hatch pattern and fonts etc. to be supporteed
Found some material but it does not seem to work.
Any experience or idea's would be welcome
http://jtbworld.com/lisp/projectpaths.htm
Re: Dwgprefix set as projectname 'current'
« Reply #1 on: January 21, 2015, 04:54:47 PM »
Lets try to clarify :
You have a drawing named : ?
At this Path : ?
And you want to do exactly what. ?
lamarn
« Reply #2 on: January 21, 2015, 07:09:09 PM »
I want to set the directory of my opened drawing to the list of support directories.
Not really a super special thought..
BlackBox
« Reply #3 on: January 22, 2015, 12:24:55 AM »
... In order to accomplish what, specifically, that you are currently unable to do?
Cheers
« Reply #4 on: January 22, 2015, 01:57:19 AM »
By default AutoCAD will find files within the current directory .. so no need to add it to the support paths.
Little test:
  1. (vl-every '(lambda (file) (findfile file)) (vl-directory-files (getvar 'dwgprefix) nil 1))
lamarn
« Reply #5 on: January 22, 2015, 05:02:49 AM »
Ok thanks.
If that's the case it won't be nessescary.
But i have some doubt it worsk with all extension types..
BlackBox
« Reply #6 on: January 22, 2015, 05:31:30 AM »
You still haven't clarified what you're trying to do.
What file extensions are you attempting to make AutoCAD 'find' in DWGPREFIX that it cannot already?
lamarn
« Reply #7 on: January 22, 2015, 06:32:08 AM »
.pat files but i noticed that these are recogniced afterwards.
(Revit produces a lot of .pat files.. need to get a grip on them)
« Reply #8 on: January 22, 2015, 07:38:31 AM »
oh, you're asking about Revit, well that's different
