This is the solution I found that works.
Dim myPPR As PromptPointResult = myDOC.Editor.GetPoint("Pick:") 'Beginning insertion point for tables
Dim otable1, otable2, otable3 As New Autodesk.AutoCAD.DatabaseServices.Table
Dim S As Int16
Dim ar As New Microsoft.VisualBasic.Collection 'The key is the collection and being able to assign a table to the variable ab below- Repeatedly
ar.Add(otable1, 1)
ar.Add(otable2, 2)
ar.Add(otable3, 3)
For i = 1 To 3
Dim ab As Autodesk.AutoCAD.DatabaseServices.Table = ar(i)
ab.Position = New Point3d(myPPR.Value.X + (S * 0.25), myPPR.Value.Y, 0) ' this sifts the insertion point of the tables
S = S + 1
ab.InsertColumns(1, 1, 2) 'Build Table
ab.InsertRows(1, 0.1, 10) 'Build Table
ab.Cells(1, 1).Value = "test" 'Insert value for test
acBlkTblRec.AppendEntity(ab) 'Add to Block Table
acTrans.AddNewlyCreatedDBObject(ab, True) ' Insert into dwg
Next
