I am trying to work from this Through The Interface tutorial here:
http://through-the-interface.typepad.com/through_the_interface/2009/05/interfacing-an-external-com-application-with-a-net-module-in-process-to-autocad-redux.html I am trying to build the COM visible component from the article but when I do the compiler tells me it could not register my assemblly because it could not load one of my referenced dll's. If I compile the code without [assembly: ComVisible(true)] i.e. I use [assembly: ComVisible(false)] then it compiles ok.
This is the compiler error:
Error 4 Cannot register assembly "E:\Visual Studio 2013\AutoCAD\LoadableComponent\LoadableComponent\bin\Debug\LoadableComponent.dll". Could not load file or assembly 'accoremgd, Version=19.1.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. LoadableComponentThe LoadableComponent.dll is created but compiler says Build Failed with the error I mentioned.
* update : I have now moved the output directory to the autocad install directory but I still receive the same error messageIf someone wants to compile this themselves I have uploaded my dll's to Google Drive here:
https://drive.google.com/a/slingblade.co.nz/folderview?id=0B-NzIeN88P9lVkdvTXhHSTlrUWM&usp=sharing Here is the code:
using System.Runtime.InteropServices;
using System.EnterpriseServices;
namespace LoadableComponent
[Guid("F26BAC4F-B905-4678-B10B-BF548FAFA3AE")]
public interface INumberAddition
[DispId(1)]
string AddNumbers(int arg1, double arg2);
[ProgId("LoadableComponent.Commands"),
Guid("3EB8AB8D-1E3F-4BA6-BCD3-EC954A756C16"),
ClassInterface(ClassInterfaceType.None)]
public class Commands : ServicedComponent, INumberAddition
// A simple test command, just to see that commands
// are loaded properly from the assembly
[CommandMethod("MYCOMMAND")]
static public void MyCommand()
Document doc =
Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
ed.WriteMessage("\nTest command executed.");
// A function to add two numbers and create a
// circle of that radius. It returns a string
// with the result of the addition, just to use
// a different return type
public string AddNumbers(int arg1, double arg2)
// During tests it proved unreliable to rely
// on DocumentManager.MdiActiveDocument
// (which was null) so we will go from the
// HostApplicationServices' WorkingDatabase
Document doc =
Database db = doc.Database;
ed.WriteMessage(
"\nAdd numbers called with {0} and {1}.",
arg1, arg2
// Perform our addition
double res = arg1 + arg2;
// Lock the document before we access it
DocumentLock loc = doc.LockDocument();
using (loc)
Transaction tr =
db.TransactionManager.StartTransaction();
using (tr)
// Create our circle
Circle cir =
new Circle(
new Point3d(0, 0, 0),
new Vector3d(0, 0, 1),
res
cir.SetDatabaseDefaults(db);
// Add it to the current space
BlockTableRecord btr =
(BlockTableRecord)tr.GetObject(
db.CurrentSpaceId,
OpenMode.ForWrite
btr.AppendEntity(cir);
tr.AddNewlyCreatedDBObject(cir, true);
// Commit the transaction
tr.Commit();
// Return our string result
return res.ToString();
Can someone help me understand what I am doing wrong? Like I said it compiles ok if I don't have the com visible switch set to true.
Since the LoadableComponent.dll creates I try to use it anyway and when I do I get this error when I try to communicate through COM:
Unable to cast COM object of type 'System.__ComObject' to interface type 'LoadableComponent.INumberAddition'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{F26BAC4F-B905-4678-B10B-BF548FAFA3AE}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).BTW I have NETLOAD'ed the dll in AutoCAD.
Here is the code from my .net app. I simple have a blank form with a button. Here is the code found under the button. I have commented below where the code is failing,
private void button1_Click(object sender, EventArgs e)
const string progID = "AutoCAD.Application.19.1";
AcadApplication acApp = null;
try
acApp =
(AcadApplication)Marshal.GetActiveObject(progID);
catch
try
Type acType =
Type.GetTypeFromProgID(progID);
acApp =
(AcadApplication)Activator.CreateInstance(
acType,
true
catch
MessageBox.Show(
"Cannot create object of type \"" +
progID + "\""
if (acApp != null)
try
acApp.Visible = true;
INumberAddition app =
(INumberAddition)acApp.GetInterfaceObject(
//====here is where I get the error====
string res = app.AddNumbers(5, 6.3);
acApp.ZoomAll();
MessageBox.Show(
this,
"AddNumbers returned: " + res
catch (Exception ex)
MessageBox.Show(
this,
"Problem executing component: " +
ex.Message
