You imply two separate questions. First, you must define (c:qsave) because the AutoCAD UI ordinarily executes commands by their international name. Second, you can define c:ksich if you wish, but doing so invites improper usage, and I highly recommend against it. If you want the KSICH command to be defined, then do not undefine it in the first place.
As for (command "_qsave") behavior, this is controlled by (initdia).
