Author Topic: multiline text formatting in custom large ribbon buttons  (Read 2174 times)
XXL66
« on: January 17, 2015, 04:17:49 AM »
hello,
how is this achieved, suppose i have 2 words fe "edit template", in BricsCAD this text is split into 2 lines below the button, however in ACAD this text stays as a single line resulting in a very wide button, that's not what i want.
ty !
Crank
Re: multiline text formatting in custom large ribbon buttons
« Reply #1 on: January 17, 2015, 11:31:41 AM »
I like this to know as well: I know it's possible, but in CUI there is no option to control this.
Perhaps it's possible to find this property if you edit RibbonRoot.cui in a .XML-editor (rename YourMenu.cuix to YourMenu.zip > Rename RibbonRoot.cui to RibbonRoot.XML).
tombu
  • ByLayer=>Not0
« Reply #2 on: January 17, 2015, 02:23:57 PM »
A carriage return is the same as it is in lisp "\n"
Tom Beauford P.S.M.
alanjt
  • Standby for witty remark...
« Reply #3 on: January 17, 2015, 03:55:02 PM »
Not true. \n is a soft return, whereas \P is a hard return. When you have numbering activated in mtext, a soft return (shift+enter) will not activate the next number.
Dropbox
Crank
« Reply #4 on: January 18, 2015, 11:35:21 AM »
\n works!  :-)
Thanks tombu
tombu
  • ByLayer=>Not0
« Reply #5 on: January 20, 2015, 01:54:08 PM »
Sorry meant it works same as in lisp (princ "\n").  That's just how I remember what it is.  Soft return does the trick for multiline text formatting in custom large ribbon buttons, but not in actual Multiline Text.
Tom Beauford P.S.M.
